Code 54
Old Oct 29, 2023 | 10:28 AM
BigBlock73's Avatar
Car: 90 IROC original owner
Engine: 5.7
Code 54
My 90 5.7 is showing code 54
54. Low voltage at fuel pump OR Low voltage at Fuel pump relay OR Output failure at quad driver module
It needs to crank longer then usual to start.
Looked in the service manual and not finding anything for code 54.
searched for 14103304 relay on line and not finding a new replacement to try
Old Oct 29, 2023 | 10:33 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Code 54
RY109 standard motors, have you checked the power off the splice going to the ecm
off the ops ?
Old Oct 29, 2023 | 10:34 AM
BigBlock73's Avatar
Engine: 5.7
Re: Code 54
54Fuel pump
circuit
  • Voltage at
    terminal B2 is less than 2 volts for 1.5 seconds since last reference pulse was received.
  • Faulty fuel pump
    relay, circuit and connections.
  • Faulty oil pressure switch.
Old Oct 29, 2023 | 10:36 AM
BigBlock73's Avatar
Engine: 5.7
Re: Code 54
OPS ?
Old Oct 29, 2023 | 10:40 AM
BigBlock73's Avatar
Engine: 5.7
Re: Code 54
Ordered relay.
Fuel pump not priming when I turn the key to run
Old Oct 29, 2023 | 10:46 AM
Engine: Lb9
Transmission: M20
Re: Code 54
Check fuse next to the battery , here’s the schematic and shows E13
Old Oct 29, 2023 | 10:49 AM
Engine: Lb9
Transmission: M20
Re: Code 54
Originally Posted by BigBlock73
OPS ?
oil pressure switch
Old Oct 29, 2023 | 11:36 AM
BigBlock73's Avatar
Engine: 5.7
Re: Code 54
Fuse is good
Have power to the relay
Relay clicks when key is turned on then clicks again a few seconds later
Wont be able to get to the OPS until later in the week
Old Oct 29, 2023 | 11:44 AM
BigBlock73's Avatar
Engine: 5.7
Re: Code 54
Have power to the orange wire at the relay
No power at the gray wire
Old Oct 29, 2023 | 11:45 AM
Engine: Lb9
Transmission: M20
Re: Code 54
Ops is backup for fp relay, follow the code 54 troubleshoot tree
Old Oct 29, 2023 | 12:17 PM
BigBlock73's Avatar
Engine: 5.7
Re: Code 54
Found the code 54 Troubleshoot Tree
The tests indicate a faulty relay
Relay ordered and will install when it arrives
Big thanks to Tuned Performance
Old Nov 1, 2023 | 06:32 AM
BigBlock73's Avatar
Engine: 5.7
Re: Code 54
Relay fixed the problem.
Bought the service manual when I purchased the car new, First time I used it for a repair.
Dennis-Z28
May 20, 2013 04:12 PM
gargoyle725
Jan 2, 2006 03:18 PM
TraviZ
Apr 20, 2004 10:55 AM
Trickie
Sep 15, 2003 06:01 PM
Vikingbrew
Apr 27, 2002 10:30 PM
