Tunerpro RT V4?
Old Mar 20, 2024 | 08:42 PM
JuanZ28's Avatar
Car: 1987 Camaro Iroc Z28
Engine: 5.7 TPI
Tunerpro RT V4?
I have a 1988 5.7L TPI with ECU 1227165. Can someone point me in the direction or have a link on what Data Stream Definition I need to data log my car.
I've downloaded one but itdoesn't seem to be working.
please see link below. Thanks.
Old Mar 22, 2024 | 09:49 PM
stew'86MCSS396's Avatar
Car: '86MCSS
Engine: 396 .030"
Transmission: M20
Re: Tunerpro RT V4?
Data looks wonky and non-existent at times.
What cable are you using???
$32b ads/adx...
Old Mar 23, 2024 | 11:03 AM
JuanZ28's Avatar
Engine: 5.7 TPI
Re: Tunerpro RT V4?
Old Mar 23, 2024 | 11:27 AM
JuanZ28's Avatar
Engine: 5.7 TPI
Re: Tunerpro RT V4?
Hi I am using a USB to TTL adapter by SB UART.
I jumper the TX and RX together and connected the wire to the car ALDL diagnostic connector port M and the Ground wire to port A.
The data is weird, I either have a bad ECU or the wrong Data Definition.
The $32b ads/ adx is that a Bin file or a Data logging Definition file? I need a data logging file for a 1988 Camaro 5.7 TPI with MAF.
Thank you.
Old Mar 23, 2024 | 11:41 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Tunerpro RT V4?
Goofy data the prom
id shouldn't change . Have you tried v5 rt with the $32B adx . Do you start data in 10k mode ?
Old Mar 23, 2024 | 12:17 PM
JuanZ28's Avatar
Engine: 5.7 TPI
Re: Tunerpro RT V4?
I've tried Tunerpro RT V5 download an ads definition file then imported it to convert to and adx file. But Tunerpro RT V5 won't connect to my ECU. I'm new to this Tunerpro RT and I'm unaware of the 10k mode.
Old Mar 23, 2024 | 12:30 PM
Engine: Lb9
Transmission: M20
Re: Tunerpro RT V4?
https://www.thirdgen.org/forums/tpi/...i-da-data.html
you can also use winaldl to see if data looks good. Before you connect tp or winaldl use a 10k ohm resistor across a to b at the aldl then hit connect.
Old Mar 23, 2024 | 03:20 PM
JuanZ28's Avatar
Engine: 5.7 TPI
Re: Tunerpro RT V4?
I will order some 10k ohm resistors.
Also Im running the Bosch3 fuel injectors and I have another ecu 16198259 that has a Delco ANYH 9298. Can you tune/burn it to be use for my car?
Old Mar 23, 2024 | 03:25 PM
Engine: Lb9
Transmission: M20
Re: Tunerpro RT V4?
The anyh memcal can be used with minor tuning . Vats delete, battery voltage offsets . Aujm is a good code to use for the 350 automatic.
Old Mar 23, 2024 | 04:07 PM
Car: '86MCSS
Engine: 396 .030"
Transmission: M20
Re: Tunerpro RT V4?
Idk a whole lot with the 1227165 ecm... Your cable interface will suffice adding the 10k ohm resistor. With winaldl or TPRT sorta remember that pin E gets you 160 baud data which is super slow whereas pin M data is transferred at 8192 baud 50x faster. I mentioned this for the mere fact that your ads file ends with "160." Idk if there's a 8192 specific ads/adx but I'd try to download something that's been more developed from one of the links provided^^^in this thread rather than what can be downloaded from tprt site. The quicker baud rate is where you wanna be for datalogging but if you're just wanting to look at snapshot data the 160 baud could suffice. i.e. TPS volts, batt volts, coolant temp, cel flags, etc...
ads/adx is the datalogging file used with tp v4 and v5 respectively.
Old Mar 23, 2024 | 04:15 PM
JuanZ28's Avatar
Engine: 5.7 TPI
Re: Tunerpro RT V4?
Thank you for this information.
Old Jul 30, 2024 | 07:55 AM
MikeJR1991's Avatar
Car: 91 Camaro Z28/1LE & 91 SLP Firehawk
Engine: 350/5.7 L98 & 383/6.3 L98
Transmission: 4L60 Automatic & T-56 6 speed
Axle/Gears: G80/G92 3:42 & WS6 3:73
Re: Tunerpro RT V4?
Can anyone still burn custom PROMS now that MOATES is out of business? I’m looking for a new chip.
eutu1960
Oct 13, 2019 06:47 AM
customblackbird
Apr 14, 2010 10:46 PM
Ryan3834me
Sep 18, 2007 10:08 AM
Christos
28
Oct 20, 2002 11:11 PM
v8power
Oct 16, 2001 07:38 PM
