Finding 2732A chips. Please check this site for me
Old Nov 6, 2001 | 09:37 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
I want to burn some chips and not mess with the stock chip other than the initial read. I know most of you are running the 256k chip for your TPI cars but not much reference to the 2732A that my 8746 ECU uses. This site has 3 different 2732A chips will any of these work. https://www.jameco.com/cgi-bin/ncomm...xt.x=28&Next.y =9
The chip burning 101 states that the 8746 ECU uses the 2732A prom chip but doesn't say anything about voltages and speed.
Old Nov 6, 2001 | 11:07 AM
86Red4+3's Avatar
Any of those 2732's will work. The programming voltage depends on your programmer - you just select 25v for the 2732, 21v for the A or 12.5v for the B version. All three are available on most programmers.
Of the 2732A's listed on that page, the cheapest has a 450 ns access speed and that is plenty fast enough. Paying more for the faster -20 (200 ns) or -25 (250 ns) chip is a waste in this application. $3.95 isn't a bad price, either.
Old Nov 6, 2001 | 11:27 AM
prscarf's Avatar
save your money and get them off ebay. i got the same chips 150ns for $15 for all 13ea. all work.
Old Nov 6, 2001 | 12:11 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by brharris27370:
I want to burn some chips and not mess with the stock chip other than the initial read. I know most of you are running the 256k chip for your TPI cars but not much reference to the 2732A that my 8746 ECU uses. This site has 3 different 2732A chips will any of these work. https://www.jameco.com/cgi-bin/ncommerce3/ExecMacro/Jameco/home.d2w/report?search=&sort=&startRowNum=1&totalSize=66&cgrfnbr=616&cgmenbr=91&ctgys=502%3B513%3B616%3B&Next.x=28& Next.y =9
</font>
Speed isn't an issue.
Neither is the programming voltage as long as you know what it is.
Astro Market in FL used to have used eproms for $1-2 a pop depending on how many you buy.
I just always went the cheap used route and ordered plenty. Couple are always junk but at a $1 a peice you can afford that vs $3-4.
Old Nov 6, 2001 | 12:19 PM
Does Astro Market have a website? My attempts at locating chips on ebay has thus far been unsuccessful.
Old Nov 6, 2001 | 01:02 PM
JPrevost's Avatar
Car: 91 Red Sled
ebay for sure, just make sure you don't get AMD. They are wider and won't fit in your stock eprom plastic holder. I don't really care since I have a zif socket. I just got 10 for $15, not bad, 5 AMD and 5 intel 2732a eproms. They're brand new and work. Just use ebay for the best prices.
Old Nov 6, 2001 | 01:12 PM
I widened my search on ebay and found some but none lists programming voltages. I just ordered my pocket programmer so I don't know much about that area yet.
JPREVOST I know you use the 8746 computer. I have seen your posts since I joined early on. What editor do you use to modify your bin. I have just been reading forums and Traxions prom burning intro before I jump head first into this thing. I thought I would start tweaking my mostly stock engine before go drop in my big 400hp mega monster and can't get it to even idle.
Old Nov 6, 2001 | 07:36 PM
Lionsden's Avatar
I ordered 5-2732a from Jameco. 2 wouldn't work. Emailed them about the defective ones and never got a reply.
Dan
Old Nov 6, 2001 | 09:14 PM
JPrevost's Avatar
Car: 91 Red Sled
I never had a problem with any of my eproms. I did ruin one of them but that was my fault. I left it in the UV light for too long and the darn thing hated me.
As for the software I use, TunerCat. By far the easiest software to tune a bin with. It does everything automatically, even compare bins to each other! I was thinking about getting the definition file (tdf) editor but it wouldn't be worth the money since he's been updating the 8746 ($61) tdf files.
Definatly start with a stock engine with stuff like open element. Play with the tables one at a time! At first I was doing 10 things at once and playing with them, by the time I ran into a jam I had no idea what I had done to cause the car to run the way it did.
Old Nov 7, 2001 | 02:20 AM
crucial's Avatar
I just went to a junkyard and jacked a bunch of Fiero and older FBody chips out of the ECMs. Most of them are 2732s and they work just fine.
Old Nov 7, 2001 | 07:20 AM
Thanks guys,
I found some 2732D's on ebay and was asking the guy about 2732A's. He had 40 A's that he hadn't listed yet so I offered him $.75 a piece for them. Should arrive in a week. I figure at that price I could have a few bad ones and not care.
On the Tuner Cat software. Is there a charge for updated definition files?
Old Nov 16, 2001 | 08:35 PM
Lionsden's Avatar
Thanks guys,
</font>
We might have been talking to the same guy. He thought the difference between the A and the D was program voltage A's are 21 and D's are 25.
He then listed 20 of the A's at a "Buy it now" price of $16. They be mine!!! If I end up with a few bad I still OK. Heck, I ordered 5 from Jameco and two never did work.
Dan
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Elliswon
Aug 10, 2015 12:33 PM
