Datalogging issue with ostrich
Old May 29, 2008 | 05:20 PM
formula350sd's Avatar
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
Ok I finally got my car out this week and got to play with some of my new toys..
I plugged in my datalogger and it worked just fine with the custom ship from fast chips that was in there but after I installed my ostrich I cant get the thing to connect to the ECM I tried like 20 times and nothing. Then it threw a code 51 which is for bad ecm but the car runs just about as good as it ever did I'm totally confused.
Any help would be greatly appreciated.
AL
Old May 29, 2008 | 05:34 PM
AC's Avatar
AC
Car: Used to drive a camaro
Re: Datalogging issue with ostrich
Is the Ostrich a USB or serial? Maybe also check your aldl cable to make sure its plugged in all the way or loose wire or something.
Old May 29, 2008 | 05:44 PM
Car: 89 Formula
Ostrich is USB and I checked the cable like a million times the sombitch is brand new so I dont thinkn its bad
Old May 29, 2008 | 06:55 PM
AC's Avatar
AC
Did it work before? I run an Ostrich 2.0 USB. The only weird thing is I have to run the ostrich in the side USB ports of my laptop and not the back...
Old May 29, 2008 | 06:56 PM
Car: 89 Formula
yeah it worked not 15 minutes before I installed the ostrich
Old May 29, 2008 | 07:08 PM
AC's Avatar
AC
Did you put the ribbon & adapter in the ECM backwards by chance?
Old May 29, 2008 | 09:34 PM
Car: 89 Formula
Thats a good qustion ill double check tomorrow but I dont think so it seemed to run pretty good seemed too well to be gimping but ill make sure in the morning
Old May 31, 2008 | 12:50 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Plug your stock chip onto the bare pins of the Ostrich cable where it plugs into the ECM.
Old Jun 1, 2008 | 06:15 PM
Car: 89 Formula
Might I ask why?
Old Jun 1, 2008 | 07:06 PM
malcom2073's Avatar
Car: 1987 IROC-Z
Engine: 383ci SBC
Can you verify that the ostrich has the correct bin file loaded on it? TunerPro has a "verify" option to make sure that the ostrich has the binary file loaded correctly. I know when I loaded a file and it failed, I was getting the same thing
Old Jun 1, 2008 | 07:24 PM
Car: 89 Formula
Ill check that next
Bubbajones_ya
Jul 6, 2024 08:32 PM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
