305 tpi to 350 tpi
Old Sep 24, 2009 | 03:30 PM
Nater36's Avatar
Car: 1989 Firebird Formula
Engine: 310 HSR, TFS heads, zz4 cam
Axle/Gears: 9 bolt 3:70
305 tpi to 350 tpi
swapping out my 305 to a reman 350 tpi. Has a t5. am i ok to keep the 305 knock sensor and original prom? I have the tuning equipment just havnt used it yet. What all am i going to need to tackle?
89 MAF
Old Sep 24, 2009 | 04:16 PM
regal301's Avatar
Car: 1988 iroc-z
Engine: 350 Vortec TPI
Axle/Gears: 3.73 4th gen Torsen 10bolt
Re: 305 tpi to 350 tpi
different prom,injectors,new 350 knock sensor....................
and if you run it hard,a new t5
Old Sep 25, 2009 | 07:02 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
you'll need the 350 knock module as well. The 305 knock sensor and knock module are calibrated differently than the 350 pieces..... Well they are different part numbers anyway, so draw your own conclusions.
Since its a MAF car you'll be OK for now with the stock PROM as long as you use the 19lb fuel injectors from the 305. If you run bigger injectors you'll have to change the injector constant in the chip.
Old Sep 25, 2009 | 07:52 AM
Nater36's Avatar
the knock module??
I have a new set of 350 injectors, 21 or 22 whichever was stock size.
Old Sep 25, 2009 | 07:59 AM
regal301's Avatar
Car: 1988 iroc-z
its right next to the brake booster.its also called the electronic spark control module.
http://www.autozone.com/autozone/cat...&parentId=62-0
Old Sep 25, 2009 | 08:01 AM
regal301's Avatar
Car: 1988 iroc-z
the car will run and be driveable without it,but to fine tune the car you need it.
the prom and injectors are the most important part.
Old Sep 25, 2009 | 08:28 AM
Nater36's Avatar
ok, ill get those two items then.
Im not going to need to switch anything in the prom other than injector size?
Old Sep 25, 2009 | 08:39 AM
regal301's Avatar
Car: 1988 iroc-z
i dont burn my own proms, i have them done.
someone else can answer that as i dont know for sure
Old Sep 25, 2009 | 08:51 AM
Nater36's Avatar
o, ok
Old Sep 25, 2009 | 12:26 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
No you should be OK with just changing the injector constant. If the 350 is bone stock and you can burn chips, why don't you just burn a stock 350 tune to the chip?
Old Sep 25, 2009 | 01:57 PM
Nater36's Avatar
because of the t5. all 350's have autos, wouldnt that mean problems?
Old Sep 25, 2009 | 10:02 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
no problems really. You can copy some of the stall saver and idle speed values from the 305 .bin if you want.
Let me clarify, i'm speaking in generalizations here. For the car to be absolutely perfect in every way, you'll need to do a little work to mesh the 305/T5 bin with the stock 350 bin. But it will run great and you wont have any major issues if you run the stock 350 bin, or put the correct injector constant in your 305 tune.
Old Sep 26, 2009 | 12:06 PM
Nater36's Avatar
alright, cool, thats what i like to hear
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
