Analog MAF Meter in use (HLM)
Car: check
Engine: check
Transmission: check
Re: Analog MAF Meter in use (HLM)
There isn't much info on the '6870 ECM around. So I can't be of a lot of help on it.
RBob.
Car: 87 GTA
Engine: Two cracked out gerbils
Transmission: 700r with a probuilt automatics kit
I too am interested in learning a little more on this subject.From what i can see in tunerpro rt If the box is checked it looks like thats setting it to analog.This is what it sure looks like to me,so unchecking the box would be in digital mode?
It says:: Analog MAF meter in use (BLM)
Then below you see the check box for setting it.I highly value your response rbob just confused because from what the tprt window looks like it appears to me like your supposed to check the box for setting the analog mode.I might just be confused and 99% of the time i am for no reason on any given subject.Thx!
Curious cdn_87iroc you are using a 1F bin and ecm with a 87 maf? Why not use a 1227165 6E ! I have all bought all the tuner cat definition for tpi years ago does tunerpro rt have a check sum for this address?
Car: check
Engine: check
Transmission: check
Having no hac of this mask, and the XDF I just downloaded not having that entry (I was going to check some stock BINs), I can't say.
RBob.
Car: 87 GTA
I see. I completely understand. Thanks forbetter explaining. Makes perfect sense.thanks.
