problem datalogging with obd diagnostic inc cable and tunerpro
Old Aug 30, 2013 | 03:54 AM
danielr1211's Avatar
Car: 90 iroc
Engine: Vortec 355 w/HSR
i purchased this cable:
http://www.obd2allinone.com/sc/detai...item=aldlobd1u
downloaded tunerpro, and the file to datalog with my 90z28 checked the cable with tunerpro and it reades the cable when i have the cable plugged in the cable and the ecm does not connect and no data streams, and it does not show connected on tunerpro. i can switch the ignition from on to off tunerpro will connect for about two seconds read data and then flash error at the bottom of the page.... ive re loaded the drivers about four times and cant seem to figure it out any suggestions?
Old Aug 30, 2013 | 08:46 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: problem datalogging with obd diagnostic inc cable and tunerpro
https://www.thirdgen.org/forums/tpi/...rpro-help.html
what is the voltage on the serial data line ?
Old Aug 30, 2013 | 10:43 PM
Car: 90 iroc
The voltage at all the pins
A.113
B5.082
C.004
F.069
K5.095
M10.44
Old Aug 30, 2013 | 10:45 PM
Engine: Lb9
Transmission: M20
M on the aldl is usually 2.5v or higher you have serial data.
Old Aug 30, 2013 | 10:58 PM
Car: 90 iroc
What would cause a no connection between the aldl cable and tunerpro?
Old Aug 30, 2013 | 10:59 PM
Engine: Lb9
Transmission: M20
Have you tried all your com ports ?
Old Aug 30, 2013 | 11:19 PM
Car: 90 iroc
I went up to com port 8. And none could establish a link other then the split second the key was turned from on to the off position
Old Aug 30, 2013 | 11:30 PM
Engine: Lb9
Transmission: M20
Just curious are you using windows 8
Old Aug 30, 2013 | 11:43 PM
Car: 90 iroc
Windows 7 home premium
Old Aug 30, 2013 | 11:58 PM
Engine: Lb9
Transmission: M20
Im not sure what to tell you to try, other than contacting the manufacture of your cable, moates, red devil river, aldlcable.com ect..
Old Aug 31, 2013 | 12:00 AM
Car: 90 iroc
Yeah. I figured it end up there just wanted to make sure my bases were covered I appreciate all the help. Thanks
Old Aug 31, 2013 | 12:04 AM
Engine: Lb9
Transmission: M20
Wish I could tell you more but sounds like you have covered it all. If you can jump the a to b on the aldl and get the check engine light to blink you would have verified the ground on pin a and the ecm diagnostic terminal.
Old Aug 31, 2013 | 12:15 AM
Car: 90 iroc
I checked it and it worked.
I went with the cable due to the moderate price being stationed in hawaii makes shipping so expensive. But as always you get what you pay for I am sure moates cable would have worked flawlessly.
Old Aug 31, 2013 | 10:40 AM
EagleMark's Avatar
Not necessarily, they are failing too now as are all cables!
We've found FTDI chips used in making these cables, not counterfit, from same lot, work with one drive and not the next. None seem to be working with latest updated driver from FDTI. But there is 1-2 old drivers that work with all.
You can't just pick a COM port and try it, in Windows 7 look in Printers and devices to see the cable and right click to find which Com port it is installed on. Then see what driver.
Here's instructions and link to the thread working on this issue:
http://www.gearhead-efi.com/Fuel-Inj...to-TunerPro-RT
Old Aug 31, 2013 | 10:43 AM
Engine: Lb9
Transmission: M20
Nice find Mark
Old Aug 31, 2013 | 10:47 AM
EagleMark's Avatar
Thanks! I did the write up on how to install a cable for TunerPro and it worked flawlessly for years.
But I am not responsible for the driver update issue found, those people are linked and should receive credit.
Old Sep 2, 2013 | 10:15 PM
Car: 90 iroc
I uninstalled all the drivers an rolled it back to a previous version. Still no luck making a link with the car. This is going to bug me till I figure it out
Old Sep 20, 2013 | 01:13 PM
Car: 90 iroc
Turns out it was a ground on the rear of the engine. when the previous owner did the swap he ripped the grounds out. Thanks for the help.
GTAman
Mar 15, 2019 11:40 AM
CORV3TT3
Aug 23, 2015 11:26 AM
tmellott89
Aug 16, 2015 02:58 PM
bamaboy0323
Aug 15, 2015 07:20 AM
