Timing tables
Old Aug 6, 2014 | 06:30 AM
htrdbmr's Avatar
Car: BMW 735
Engine: 383 W/ SUPERAM
Axle/Gears: 3.64
Timing tables
I'm new to this, and in the past few weeks I've gotten the VE tables close enough to move on. Now I'm working on the SA tables, and I'm lost. I have a 727 ecm, and I'm using TunerPro along with Data analyzer V11. Is there any way to group the knock counts into cells (0-15) similar to the BLM cells, so the SA could be adjusted by cell rather than rpm vs kpa? I've searched a lot of posts, and the FAQ's, and I'm just not getting it.
Old Aug 6, 2014 | 01:03 PM
Ronny's Avatar
Re: Timing tables
First thing is identify if due to A/F or fuel or mechanical.
WOT can be optimized by MPH 1/4 mile with no KC.
Keep in mind optimal results on a dyno like the mfg's do.
Old Aug 6, 2014 | 01:13 PM
htrdbmr's Avatar
Car: BMW 735
Axle/Gears: 3.64
Re: Timing tables
Thanks for the reply, A/F's were bad rich when I started (108-116) Now that I have them at an acceptable level (124-131) I'm getting 1-6 degrees of knock retard depending on where the rpm/kpa is at.
Old Aug 6, 2014 | 01:16 PM
Ronny's Avatar
Re: Timing tables
Pull timing globally and see if it goes away. If not it is mechanical
Old Aug 6, 2014 | 01:24 PM
htrdbmr's Avatar
Car: BMW 735
Axle/Gears: 3.64
Re: Timing tables
by that do you mean applying say a .85 correction to all cells in the main sa table?
Old Aug 6, 2014 | 02:26 PM
Ronny's Avatar
Re: Timing tables
yes
Old Aug 6, 2014 | 02:31 PM
htrdbmr's Avatar
Car: BMW 735
Axle/Gears: 3.64
Re: Timing tables
Thanks, I'll try it tonight.
Old Aug 6, 2014 | 02:40 PM
Ronny's Avatar
Re: Timing tables
The other option is race fuel added 50/50. I have a station near my home!
Azrael91966669
25
Jun 20, 2017 04:04 AM
fasteddi
Sep 2, 2015 10:29 AM
htrdbmr
Aug 18, 2015 12:58 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
