EMP-10 Burner Power Supply
Old 03-24-2018, 01:24 PM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
I still need to burn eproms at times but seemed to have "misplaced" the power supply for my Needham's EMP-10 burner. Is there one available or does anyone know the spec on them?
Old 03-24-2018, 04:52 PM
ULTM8Z's Avatar
Re: EMP-10 Burner Power Supply
Dom, typically the device has the input voltage listed on it near the plug for the AC adapter. Is this not the case for this chip burner? If you can find that, then any AC adapter would work provided the polarity is correct (typically the pos is the center pin on fast majority of these things anyway)
Old 03-24-2018, 05:11 PM
ULTM8Z's Avatar
Found a couple of things browsing around...
https://i.ebayimg.com/images/g/Wr0AAOSwIspaV8K3/s-l400.jpg
note it says 12V... but AC, not DC.
also this link which seems to corroborate...
https://www.seanet.com/~karllunt/emp10.html
Old 03-24-2018, 05:12 PM
ULTM8Z's Avatar
Double post...
Old 03-24-2018, 09:15 PM
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
https://i.ebayimg.com/images/g/Wr0AA...8K3/s-l400.jpg
Awesome. Thanks ULT.
Old 04-03-2018, 08:08 AM
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Loooks like this is the power supply I’m looking for.
Attached Thumbnails EMP-10 Burner Power Supply-ccacaa52-d63d-407f-b2ad
Old 04-03-2018, 08:42 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
That one is for overseas, not the US. Note the primary rating of 230V 50 Hz. Need one that is 110/120V 60 Hz.
RBob.
Old 04-03-2018, 01:10 PM
daferris's Avatar
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
Not sure the connector you need but the output is 12v 1amp a generic power supply or battery voltage would work. You just need to make sure the polarity is correct...
Old 04-03-2018, 01:34 PM
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Thanks guys. Think I found a suitable power supply. 12v 1000ma. Connected to my Windows 98 Toshiba (WOW!) and ran the software fine. I'm going to try burning a prom and see if that part works.
Old 04-03-2018, 10:26 PM
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Burned a cal and yeah the prom worked. Case closed.
Old 04-04-2018, 11:01 AM
ULTM8Z's Avatar
Gotta love a happy ending
monte-ss
05-04-2002 10:13 AM
brettd
08-10-2001 12:35 PM
Quick Reply: EMP-10 Burner Power Supply
