Is this okay?!?
Old Mar 13, 2021 | 12:26 AM
badgta's Avatar
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
Is this okay?!?
Looking at the VE Extened upper RPM tables. All are blank?!!?
I am guessing because of what i am using perhaps? Here are all the files, XDF etc i am using. Just weird because the lower tables don't even match the original upper tables let alone the zero'd new upper/upper tables.
Also, i was (JUST LOOKING) at advance spark and seen some 40*+ areas, kind of worried me some... If you think i need to dial them down i can. She has a 160* Thermostat, fans on at 170* and 9.6:1 Compression (ALWAYS) 93+ Octane (NO LESS) Not even 91 !!!! Also seen a AFR table at 15-16:1, VS KPA... I can dial them down to 14.7:1 MAX if needed also.
8D XDF, SUPER AUJP ETC: https://www.mediafire.com/file/r2kru...stuff.zip/file
My Formula Bin Fastburn 385 LT4 HC A4 : https://www.mediafire.com/file/dl2jn...LANEW.bin/file
Old Mar 13, 2021 | 10:52 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Is this okay?!?
Are you using super aujp xdf to look at a $8d non saujp binary file ?
Old Mar 13, 2021 | 12:20 PM
badgta's Avatar
Car: 1991 FORMULA
Re: Is this okay?!?
i don't know if it is or not.. You cannot find a good 8d dxf regular file anymore. It's all "SUPER" stuff. I don't know if it is or not, i took it as a regular one..
Old Mar 13, 2021 | 01:35 PM
Engine: Lb9
Transmission: M20
Re: Is this okay?!?
Tuner pro.net has the ads to convert to adx or gearhead efi has it too
Old Mar 13, 2021 | 01:43 PM
badgta's Avatar
Car: 1991 FORMULA
Re: Is this okay?!?
I am waiting for approval on Gearhead....
This is all i can find on tuner pro... The ecu file is super 8d, and i cannot use the vette adx because wasn't the vette a 6 speed?
Old Mar 13, 2021 | 02:07 PM
badgta's Avatar
Car: 1991 FORMULA
Re: Is this okay?!?
I tried the whole "CONVERTING .ADS to .ADX, but i am not getting the proper menu under the "COMMANDS" tab.
This is what mine shows. Doesn't matter which i try ot use, i am still getting that "UPPER V.E" that is blank across the board, as if it was wrote on it like that?!?
Going by Maotes conversion "HOW TO"... Only one that looks like that listed under "COMMANDS" is ALDL DUMP REQUEST REPLY.. I changed the 66 to 67 in that one, it is identical just named different. Still doesn't change anything, on that VE table that is.
http://support.moates.net/tprtv5-ads-to-adx/
Old Mar 13, 2021 | 02:38 PM
Engine: Lb9
Transmission: M20
Re: Is this okay?!?
Sorry intended to say they have xdf. Will try to upload it here
Old Mar 13, 2021 | 02:48 PM
Engine: Lb9
Transmission: M20
Re: Is this okay?!?
my attachments aren't working on my slow satellite internet. your tune is not s_aujp based but aujp $8d based. edit using the $8d xdf
Old Mar 13, 2021 | 02:56 PM
badgta's Avatar
Car: 1991 FORMULA
Re: Is this okay?!?
Here is the link to the stuff i am using currently: https://www.mediafire.com/file/da555...1h/8D.zip/file
Using those files, the upper VE table is still showing all zeros which makes me think it was programmed that way. Maybe the computer doesn't look at VE at those upper RPMs.. I just went ahead and copied/pasted all the original tables into it, and used the last line info across to fill up the last 2 rows...
All i know to do.
Old Mar 13, 2021 | 03:06 PM
Engine: Lb9
Transmission: M20
Re: Is this okay?!?
Extended ve is a different code patch
Old Mar 13, 2021 | 08:16 PM
badgta's Avatar
Car: 1991 FORMULA
Re: Is this okay?!?
so i can leave it alone?
Old Mar 13, 2021 | 08:28 PM
Engine: Lb9
Transmission: M20
Re: Is this okay?!?
Your viewing the bin wrong
Old Mar 13, 2021 | 09:20 PM
rt66er's Avatar
Car: 1990 Pontiac Firebird Formula
Engine: L31 350 TPI
Transmission: Tremec TKX
Axle/Gears: 3.23 Posi
Re: Is this okay?!?
Not sure if this will work or not, but this is what I used...
File Type: zip
Old Mar 13, 2021 | 10:13 PM
badgta's Avatar
Car: 1991 FORMULA
Re: Is this okay?!?
Looks (A LOT) different but more factory, THANK YOU! Just what i needed!
Now, lets see if she works fine tomorrow!!
Old Mar 15, 2021 | 12:36 AM
badgta's Avatar
Car: 1991 FORMULA
Re: Is this okay?!?
Thank You for this.. I did a burn based off the original bin and modified the injector rate. Smooth as a baby.
THANK YOU!!
I owe ya one!!
MikeT 88IROC350
Jul 3, 2014 08:48 PM
Viprklr
Dec 1, 2007 04:59 PM
Desert86Roc
Aug 8, 2007 01:33 PM
lakeffect2
Apr 15, 2007 02:40 PM
JP86SS
Jun 14, 2004 08:13 PM
