HELP battery wont recharge
Old May 16, 2003 | 05:06 PM
lankchevy_350's Avatar
i cant figure out whats wrong with my car. my battery isnt recharging. of course i figured it was alternater so i went and got it checked and its prefect. i thought it might be my amp so i checked it and that wasnt it either. me or my dad both have no idea what else it could be. so someone help me out cause till this gets fixed i have to get rides with friends or walk so i need to get this fixed asap.thanks in advance
kolby
Old May 16, 2003 | 05:57 PM
91Z28-350's Avatar
batteries don't last forever. Get a new one.
Old May 18, 2003 | 12:37 PM
the battery is two weeks old
Old May 18, 2003 | 11:40 PM
scuzzy's Avatar
what brand? where did you buy it from?
and yeah, this matters. I've seen dozens of walmart brand
batteries die once they get under high stress, and never
recover.
Old May 18, 2003 | 11:48 PM
L98torque's Avatar
what's a good battery to buy?
Old May 21, 2003 | 02:10 PM
im at school right now so cant remeber the battery name but i bought it from oreilys. what high stress would a 3.1 be putting on a battery? the battery will last about 2 days if u put it back on the charger so its not the battery.
kolby
Old May 21, 2003 | 04:06 PM
91Z28-350's Avatar
the battery is fine, since it's new. It could be a bad starter solenoid.
Old May 21, 2003 | 05:07 PM
MasterEvilAce's Avatar
Starter solenoid causing the alt to not charge?........................
Anyways. Make sure all of the fuses have a GOOD connection. My alternator is connected to a fuse labeled "FAN" or something like that.
The metal pieces that the fuse slides into, on one side they're too far appart, making a bad connection. If you HOLD the fuse in there, it'll charge, else, it just sort of slides out.
See if that's your problem, if it is, either fix it somehow, or rig it.
We have these thin fuses and the metal pieces would keep sliding out of the cover everytime i'd pull the fuses out, so I just took two metal pieces out, put one full metal piece in there, then I broke the mid section of another thin fuse and took the two end pieces of the fuse, and shoved them in there so it makes it wider, and makes a connection. Works great, and... in THEORY, the fuse will still break if too much power is put through it. :P
Old May 21, 2003 | 05:23 PM
91Z28-350's Avatar
No, it's charging, but it's getting drained. That's my interpretation of the problem.
I'd also check the battery cables to make sure that none of it is loose.
Old May 22, 2003 | 12:03 PM
SC2camaro's Avatar
Car: 87 BUICK GN
Engine: 3.8 TURBO
Transmission: 200R4
hey guys
hey lankchevy
When you had the ALT checked was it on the car or off. I work at advance auto and i see this all the time. The first thing to check is to see if the Red wire the connects to the back of the ALT has +12 volts on it. If it does not have 12 volts on it you have somehow blowed the fusiable link at the starter. sounds like the problem.
Because it the alt is charging on the car you must have a pretty big short in the electrical system to over come the alt and drain the battery.
Falcon50
Aug 22, 2020 03:26 PM
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
drumstixer
Sep 29, 2015 03:02 PM
