How to removed cruise control harness
Old May 28, 2003 | 08:22 PM
Justin 87 GTA.'s Avatar
Hi,.. I am in the process of cleaning my engine compartment. I was curious as to how exactly to remove the cruise control stuff. I removed the unit. Now, my questions are,..... there is a 5 wire male connector. I want to remove that. I was thnking of cutting it back, but I want to be sure there is ABSOLUTELY NO CHANCE of it ever starting a fire. I'd like to cut it back to the firewall, and tape off the ends.
Second, there is what appears to be a large vaccum hose. It runs with the wire back to the firewall by the streering shaft. Anyway, how do i remove it? Do i cut it back to the wall and then cap it? Or do i remove it from inside the car? I don't want it to leak.,,, and i want it done the right way. I have a supercharger.
Third, there is what appears to be a double ground wire coming from the same loom or harness, near the firewall, and it attaches to the fender. Should I leave it intact or remove it? Does it ground something other than the cruise control also? What is the safe way to do it?
Please only answer if you know for sure what the proper safe way to do it is. I've seenn cars burn before, and i don't want mine too. Too much into it. Everyone i talk to says they think i can snip them and it "should" be fine. That answer isn't good enough for me thanks very much, any help is greatly appreciated/
--Oh also: there is a 4 port connector (2 male and 2 female) pin type connector, with 1 black and 1 blue/black wire coming into it. I believe it was for the a/c before i removed it. Anyway,.. do you know how to eliminate this safely????? thanks
Old May 31, 2003 | 02:44 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
Justin
when I removed the cruise harness from a 87 TPI trans am, I simply unplugged it from the brake switches and theres another plug to, also you have to remove the vacuum line from a brake switch then theres a ground wire near the back side of the drivers side fender near the relays then simply pull the whole harness out and put a rubber plug in the harnesses hole.
Old May 31, 2003 | 09:09 PM
that's great info thanks. But a couple of questions. Do you have to "cap" the vaccum line where you remove it? And where is the brake switch exactly, and how do you get to it? and what about the a/c connector in my original post. thanks -Justin
Old Jun 1, 2003 | 03:35 AM
Jproz1167's Avatar
justin
look right by the brake pedal itself and you will see the switches and you will also see the cruise harness coming from through the firewall. as for the a/c plug, I believe the 4 pin one connects to the ecm, DONT mess with it or when you turn a/c on ecm will not turn the engines rpm up
Old Jun 1, 2003 | 10:45 AM
I already removed the a/c,... so ca i pull it out, or will it affect the rpms w/ the heater motor on? Should i just leave it? thanks a lot!
Old Jun 5, 2003 | 09:47 PM
vjo90RS8's Avatar
Car: 2002 Z28
Im am also in the process of removing my cruise control and AC stuff.
AC is out, AC control unit wiring it out, non AC controls wired up, next i need to remove all the wiring for the compressor and any onther wiring that was once used by the AC.
I have removed my cruise control parts but have not touched the wiring yet so am more posts on this topic will be much appreciated. I know there is a lot of vacuum hoses and wiring that i can get rid of by removing the AC and CC. Also, you might want to think about adding a manual fan switch if you already havent, pretty straight-forward, just have to ground one of the Fan Relay wires, i used a inline 20A fuse and a 20A max rated toggle switch.
About the old cruise control vacuum lines, you have to plug them, but when i was analyzing the vacuum setup there is a vacuum tap in the back of the intake manifold that supplies vacuum to AC control unit and the cruise control, and as far as i can see, nothing else. If you can, just remove the tap from the intake and cover it up with a bolt, thats what im going to do if everything checks out right. I have to wait another week until school is out and i can get back home to work on my car.
Keep the posts coming, i want my car to look like it came from the factory without AC or CC.
Old Jun 12, 2003 | 11:19 PM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
If you guys are removing the curise control stuff from your cars, I'm looking to buy it to add to mine. Let me know if your interested. Post pics too!
Old Jun 12, 2003 | 11:43 PM
vjo90RS8's Avatar
Car: 2002 Z28
ill try to keep everything as complete as possible, i just finished my last final and am going back home tomorrow. ill probably have it completely remove sometime next week. ill give it to your for a good price if you still need it by the time it is available.
Old Jun 13, 2003 | 12:05 AM
That would be awsome, I need some pics if you can, still trying to figure out if the wiring is there for it in my car or not. just a quick glance I don't see the harness that plugs into the servo, is that what comes thru the fire wall from the brake pedal along with the vacum line???
Old Nov 18, 2003 | 11:12 PM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
can we finish this topic, i just got back under the hood, literally,.. I pulled the 5 wire grey connector I guess for a/c and the vaccumm line through the firewall into the inside of the car. how do i remove them and do i need to cap the lines,. and how do the wires disconnect? thanks/
Old Nov 19, 2003 | 12:00 AM
Yeah vjo90RS8 never got back to me on those parts, would really like to install it on my Camaro.
Old Nov 19, 2003 | 01:32 AM
vjo90RS8's Avatar
Car: 2002 Z28
hey sorry about that man, i totally forgot....i was able to remove the vacuum tank and the cruise control controller (whatever that thing is called new the vapor canister) and the wiring harness for it but i realized that there is much more wiring up under the dash that i wasnt able to remove. So what i removed is definately not the complete system. I will be willing to sell the harness and "controller" with the linkage and the vacuum tank although i broke off the fitting when i was removing it, might be able to glue it back on. If you want this stuff let me know, ill be going back home from college for thanksgiving break in about a week so i can get everything together. I will see it for cheap, just give me $5-10 bucks and pay for shipping and its yours, and im sure shipping wont even be that much.
Old Nov 19, 2003 | 11:36 AM
One more thing I need is the electronic crusie module thats directly behind the A/C consel, should be able to get at it from the top under the top dash board. (might be deeper, may have to reach in, but it will be braketed to the back of the A/C consol.)
There will be a wire harness going up the column to the crusie switch, if you can pull that, that would be helpful, it unplugs about 5 inchs below the arm in the colum, should lead you back down to the bottom where there might be other crusie stuff you can pull.
Last but not least, I need the crusie parts that are on the brake pedal braket, down by the fire wall, like the valve and vacum hose.
Two bad you don't have a digital camara so I could see what broke, but for $5 bucks I'll take that part w/ braket and linkage. Let me know on price for the other stuff.
If that harness was just unpluged and taken out, i'll buy that too, but if it was cut it won't do me any good. Any and all vacum lines.
The main thing to work on is that electronic module, have to get it from the top, so if you where thinking of putting in new speakers LOL heres your chance while you have the top board off.
Old Nov 19, 2003 | 09:47 PM
Car: 1987 GTA
i'd still like to know what exactly can be removed and how,.. anyone? thanks
Old Nov 20, 2003 | 12:07 AM
Justin 87 GTA
You can remove the servo (don't make a vacum leak), you can remove the linkage, the electronic module, and vacum line and wires.
Old Nov 20, 2003 | 01:26 AM
vjo90RS8's Avatar
Car: 2002 Z28
im in school right now but will be going home during thanksgiving break. Im thinking that i cut the harness in order to remove it but it can just be reconnected to the connector. On the vacuum tank i broke the nipple that the vacuum line was connected to when i tried to pull out the hose, it was like the thing was welded on there. No sure if u can fix this or not. Ill try to organize everything when i go home the only thing is i plan on installing my ProBuilt tranny and ACT torque converter over the break so hopefully i will have time to do the cruise control stuff too.
Old Nov 20, 2003 | 01:29 AM
do you mean the vacum tank or the servo that has the linkage??
Because you need that vacum tank for your car.
Old Nov 20, 2003 | 01:40 AM
vjo90RS8's Avatar
Car: 2002 Z28
why do i need that vacuum tank, in the diagrams i have it is only used for cruise control. I have emilinated everything that goes to the vacuum port at the back of the intake so i have that capped.
Old Nov 20, 2003 | 10:09 AM
Car: 1987 GTA
rayn, where is all that stuff, do you have pics? thanks a lot!
Old Nov 20, 2003 | 12:15 PM
Well did you break the fitting on the vacum tank or the servo(w/ linkage) If it was the vacum tank then we are all good cause I don't need the big ball tank.
Justin 87 GTA, the servo has linkage that goes from it to the butterfly, follow it back and you will find it either on the left or right side of the engine compartment.
Old Nov 20, 2003 | 01:36 PM
vjo90RS8's Avatar
Car: 2002 Z28
just the fitting on the big black ball vacuum tank, the servo should be in good shape. Wednesday or thursday of next week i should be able to get you a detailed list of what i have and what i can get you.
Old Dec 16, 2003 | 12:26 PM
vjo90RS8, hey what happen, lose my email or what??
Old Dec 16, 2003 | 09:27 PM
vjo90RS8's Avatar
Car: 2002 Z28
hey man, i am so sorry, i just got done with finals and i just started working for the christmas break. Give me your shipping info and ill get the cost of shipping on friday FOR SURE!!!. Ill give you the servo for free since i was so slow getting back to you. When i get the shipping costs ill give you my friends paypal account so that u can send the money. Again, sorry for the delay, just been kinda busy and plus my alternator just went out and i had to spend my last 100 bucks to replace it.
DAVID
Old Dec 17, 2003 | 11:43 PM
hogballer96 at hotmail.com I sent my address to that email so let me know.
eightsixseven
Dec 16, 2024 01:50 PM
Street Lethal
Aug 13, 2015 08:28 PM
stalkier
Aug 13, 2015 12:59 PM
Street Lethal
Aug 12, 2015 11:33 AM
Bull86
Aug 10, 2015 05:43 PM
