could this kill a battery?
Old Mar 17, 2004 | 05:11 PM
Farfire70's Avatar
I noticed the other day that my dome light was out. I removed the cover and found the bulb slightly mis-colored but when i went to remove it i touched it a little and it turned on. I shrugged my shoulders and went on my way. Now today my battery is dead. I get in the car and find the dome light is off again. When i touch it, again it turns on. There appears to be a burn look to the plastic where the bulb goes but i'm not sure if it is b/c of this. Woudl this be the problem with my battery being dead?
Old Mar 18, 2004 | 10:12 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Most likely not. The light only lights when the door switch or dash switch lets it.
Old Mar 18, 2004 | 10:42 AM
Farfire70's Avatar
That's what I figured. Do you think it's because of the recent cold weather? I'm a little confused by this all.
Old Mar 19, 2004 | 09:17 AM
dankhound's Avatar
Car: 91 RS
It is possible it just went bad due to time. How old is it?
Old Mar 19, 2004 | 09:21 AM
Farfire70's Avatar
Actually, i just replaced it in september. I replaced my starter yyesterday b/c when me and my friend tried to jump the car there was just a clicking that seemed to be coming from the starter. After i replaced it it jump started fine and this morning it started up without much of a problem. I'm just gonna have to wait and see. is it possible that the starter was draining the battery?
Old Mar 20, 2004 | 08:15 AM
dankhound's Avatar
Car: 91 RS
Its posible but unlikely that the starter was drawing current. Most likely it was something else that was drawing current.
If you have a meter you can check for current draws at the fuse box.
Old Mar 20, 2004 | 12:23 PM
Farfire70's Avatar
would i just measure the amps at the fuse box?
Old Mar 21, 2004 | 08:34 AM
dankhound's Avatar
Car: 91 RS
Pull a fuse with the key off. Place your meter in its place. Turn the key to on but not start. Then turn the key off. You should definatly have under 1amp ideally less that .5amps.
Old Mar 21, 2004 | 03:20 PM
Farfire70's Avatar
thanks, I'll have to check that out
Falcon50
Aug 22, 2020 03:26 PM
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
drumstixer
Sep 29, 2015 03:02 PM
