resistance in "L" wire on alternator?
Old Aug 13, 2005 | 09:23 AM
formulajoe_3's Avatar
Car: 89 fomula
ive searched the archives and couldnt find the info i was needing. I read on here once about installing a resistor inline on the brown wire coming off the alternator to regulate voltage to 12V. I used this on another formula of mine and it worked, but i cant remember the value of the resistor that i used. Does anyone know?
Old Aug 13, 2005 | 10:28 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The resistance value of that resistor that was used in the older models was 10 OHM's. Hope this helps you.
Old Aug 13, 2005 | 12:16 PM
Vader's Avatar
Is this what you are trying to emulate?
Old Aug 13, 2005 | 01:34 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
That is what he is trying to emulate VADER, however in your picture there it doesn't show the period between the second and last ZERO very well so it looks like 100 OHM's instead of 10 OHM's.
Old Oct 9, 2005 | 05:57 PM
Car: 89 fomula
so what would the resistor value need to be to show the 10ohm resistance? 10 ohm 1 watt?
Old Oct 9, 2005 | 09:44 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Just 10 OHM's, the wattage isn't relevant.
Old Oct 10, 2005 | 08:24 PM
Car: 89 fomula
'preciate it
Old Oct 15, 2005 | 08:56 AM
Vader's Avatar
That diagram may have been from a Corvette. They are wired differently.
Old Oct 15, 2005 | 09:13 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
Is there a minimum wattage the resistor needs to be or is like 1/4W fine? I can't imagine there's too much current going through that wire.
Old Oct 15, 2005 | 09:40 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
As mentioned in the fourth post above yours, the wattage is irrelevant to the issue here.
Old Oct 16, 2005 | 01:17 PM
Car: '87 Camaro LT
Engine: 355 L98
sorry, missed that part lol
Old Oct 16, 2005 | 06:34 PM
Car: 89 fomula
i put a 10 ohm 1 watt resistor on that wire and it did the trick. Voltage shows just over 13 on the gauge.
eightsixseven
Dec 16, 2024 01:50 PM
db057
Sep 4, 2015 07:57 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
