need help with ac compressor clutch wiring
Old Jun 5, 2006 | 11:47 PM
Green89IROC305's Avatar
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
i have an 89 iroc 305 tpi and i have a residual ac charge. the problem is that the plug for the ac clutch is inexplicably missing. can someone thell me where the wires for this come from so i can either rewire one in or find the actual plug i have looked for about 10 minutes but i cant find it. its the plug that plugs into the front of the compressor that control the magnetics for the compressor pully.
any help would be appreciated.
Old Jun 6, 2006 | 12:04 AM
wulff's Avatar
Car: 1987 Monte Carlo SS
Engine: 406 TPI
Transmission: T56 6-speed
It is a green wire and it is usually in a harness and it goes over near the accumulator and the 'cycling switch'.. you can buy a new connector at any auto parts, make sure you use one as they have a diode across the terminal to prevent the clutch from hanging up and staying engaged.
Old Jun 6, 2006 | 12:06 AM
Engine: 383 HSR EBL
alright thanks.
Old Jun 6, 2006 | 01:44 PM
Engine: 383 HSR EBL
im still at a loss heres some pics to help me explain.
this is a picture of my compressor the plug in the middle has no plug going to it and no plug in sight.
this is the plug with the green wire and the diode. as you can see it will not fit into the plug shown above. i just got back from the yard and most of the compressors had this plug plugged into them. do i just have a strange compressor or something w.
what can i do to get it working to see if my system works.
thanks in advance
Old Jun 6, 2006 | 02:27 PM
91CamaroRS305's Avatar
Car: Only a daily driver, but comin home
Engine: I have one that runs ;)
Transmission: Caged hamster that runs really fast
Axle/Gears: They are round, I know that much
Here are some diagrams if this helps at all
Old Jun 6, 2006 | 03:06 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
That is the plug for the compressor, but it is for the older clutches. parts stores sell an adapter if you don't want to cut wires. It is made by murray and the part number is 37218. The pigtail to splice in is 37215. Both are availible through O'Reillys
Old Jun 6, 2006 | 08:01 PM
Engine: 383 HSR EBL
i dont mind cutting wires its not too hard my question is what car should i look for for getting the right connector for my compressor.
Old Jun 6, 2006 | 08:10 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Most of the newer GM cars about 88 and newer use that plug.
Old Jun 6, 2006 | 08:45 PM
Engine: 383 HSR EBL
cool ill go to the yard tomorrow than.
any idea why i have the old connector and the newer plug.
Old Jun 6, 2006 | 11:32 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
I would assume your compressor has been changed.
soarestransam
Sep 1, 2015 04:00 PM
TheExaminer
Aug 25, 2015 07:34 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
rsrmoore
Aug 7, 2015 08:44 PM
