Flaky Speedometer
Old Oct 20, 2007 | 04:15 PM
jccaclimber's Avatar
Car: 1991 RS Camaro
Engine: 350 0.060" over
Flaky Speedometer
Having searched around a bit I haven't found out quite wha I'm after so here goes:
I have a 1991 RS that had a carbed 350 swapped in by the previous owner. Lately my speedometer has only been working when its warm out, or after I drive for a while so I figured that there's a loose connection of some sort. Being a 91 I assumed that it was an electric speedometer but I've seen several posts on the board here implying that it is impossible to have the electric speedo without an ECM and I'm pretty sure that was removed when the engine was swapped for a carbed one. Looking under the car I found a plug coming from the back of the 700r4 transmission which I assume is a speed sensor of some sort and I didn't see anything that looked like a speedometer cable. Also one wire (green insulation) is simply flapping in the wind and I'm not sure which wires are which to begin with. Does anyone have a wiring diagram for this? Also, what else should I be looking for in the process of solving the problem? I'm assuming the hanging wire isn't doing much since the speedometer does work at times. Perhaps being green its a ground?
Old Oct 21, 2007 | 11:18 PM
Car: 1991 RS Camaro
Re: Flaky Speedometer
Anyone?
If this is something obvious that I somehow missed in my searching at least tell me that and I'll go search more.
Old Oct 22, 2007 | 07:22 AM
tom camaro's Avatar
Car: 83 Camaro
Engine: LT1 SD Mode 30lb/hr
I think they don't like answering questions about speedo's around here
I haven't got any replys to my autometer speedo question yet either
https://www.thirdgen.org/forums/elec...-problems.html
Sounds like we are having smiliar problems.
Old Oct 22, 2007 | 11:58 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The ECMs didnt drive the speedo's in the RS's. There is a buffer box under the dash that split the signal from the VSS and sent it to the ECM and the speedo.
Old Oct 22, 2007 | 12:31 PM
Car: 1991 RS Camaro
So at least it is possible. Thank you for the reply, I'll try to track that down now that I know what I'm looking for.
Old Oct 24, 2007 | 10:05 PM
dspencer24's Avatar
Car: 91 z28
Engine: 350/ported accel tpi/AFR 195
Transmission: t-5 =(
Axle/Gears: 345
any luck my car is having the same problem and its annoying
Old Oct 24, 2007 | 10:14 PM
Bandit5's Avatar
Dig you guys ever try pushing against the instrument cluster when the speedometer is not working and see if that fixes it while you push it in a certain place?
A common problem with the later clusters is that the connectors on the back can lose connectivity when they aren't positioned exactly right. You can take off the cluster and bend the prongs up to make them contact better, and you can adjust the torque of the 4 bolts holding it in place.
Since it works when it is warm out or after warming up, it is likely just a loose connection somewhere... metal expands when it gets warmer. I had a similar problem with a broken turn signal switch, would only work when it was really hot. So if those connections are fine, I would dig around and just look for loose wires. But start with my first suggestion as it is by far the easiest to fix.
Old Oct 24, 2007 | 10:19 PM
Car: 1991 RS Camaro
I was thinking the same thing about a loose connection although I haven't found it yet. I didn't know the connections on the back were known for being bad so thank you. I'll try the wires on the back as soon as I can tear it apart. However, how I can't press on the gauge as there's the clear plastic plate in front of it. I am still a little bothered by the cut green wire though.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
