problems with Berlinneta wiring
Old Feb 4, 2008 | 06:25 PM
jlpunt's Avatar
I am having problems wiring up my new engine in my 1984 Berlinneta.The wiring harness must be different than other Camaro's because the wiring harness you have listed on here doesn't match up with my harness.Any help and I will be gratfull to you.
Old Feb 11, 2008 | 10:19 PM
1985transmaro's Avatar
Car: 1985 Camaro-1986 Trans-Am Cross
Engine: 5.0L, Fresh From A Rebuild
Transmission: 700R4 Shift Kit
Axle/Gears: 3.03 Std.
Re: problems with Berlinneta wiring
the harness is different for the berlinettas. it can be made to work, but it is more time and cost effective to try to find a factory harness. what engine did you put in?
Old Feb 12, 2008 | 02:34 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
why or how would the engine harness be any different ?
will be the same plugs for the alternator, starter, distributor BATT and TACH spades, and so on... as in any other gm vehicle in the '70's and '80's
no difference
good luck
Old Feb 12, 2008 | 10:00 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
The difference from the digital Berlinetta engine harness to that of a "regular" Camaro is that the Wiper motor plugs are different, there are 2 wires for the electric Speedo Sending unit.
There are also wires for the wiper washer and Radiator Fluid levels. but those *might* be on the ECM harness. ( I can't remember right now! )
Old Feb 15, 2008 | 08:23 AM
Mike M's Avatar
Everybody should listen to this guy in Rhode Island. He is a freakin genius when it comes to Berlinetta's. And don't let ANYBODY talk you out of changing anything out of your Berly like the radio or the dash. When everything works, it is magical. My Berly is fully functional thanks to him. John is a frikkin magician with them. (Hi John)
Mike M
Old Feb 15, 2008 | 08:28 AM
Mike M's Avatar
John, I am in the mood to fix the temp gauge. It reads low all the time. It barely moves when the engine is warm. Any ideas? I've swapped out the sender with a new one. I've even taken resistance readings from the hot sender and duplicated them on one of my other Berlinetta's. Those gauges work correctly. Is it possible for the gauge to be out of calibration? I doubt seriously if it is a wiring short as nothing has been modified on the harness. It is still virgin. I really don't want to remove the cluster right now but if I absolutely have to I want to be damned sure when I put it back there will be no reason to remove the f***r in the near future.
Mike M
Old Feb 15, 2008 | 01:34 PM
John in RI's Avatar
Thanx Mike -
It was good hearing from Ya',..... I sent a Private E-Mail to you earlier today !
Old Feb 25, 2008 | 04:44 PM
John in RI's Avatar
I wanted to post these pics on the web for awhile so that you could download them if needed. I'll leave then for a month or 2 before deleting the files.
The shop manual calls for using the "J33431-A IP" Tester and the "J33431-30" Test Adapter. I figure that info is useless,...... The Third Page will check to see how far off the gage calibration is !
Enjoy !
Old Jul 17, 2021 | 06:27 PM
Surpluzz's Avatar
Hard to find. Hope he can help me too. Lemme know how it goes. 1991 Z28
Old Jul 17, 2021 | 06:34 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
After 13 years, I'm sure it went well...
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Bert87
Aug 23, 2015 03:50 PM
Fronzizzle
Aug 17, 2015 02:52 PM
