Turn Signals Ground Problem
Old Nov 23, 2008 | 10:07 AM
Mgb86's Avatar
Car: 89 Camaro RS
Engine: Carb'd 350
Axle/Gears: 3.70
I have been having a problem with my turn signals. I can put a fuse in and they will work one or tow times then the fuse blows and they won't work. I have replaced the turn signal switch so I think that its a bad ground somewhere and was wondering if anyone knew where to start.
Old Nov 23, 2008 | 10:17 AM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Re: Turn Signals Ground Problem
The tail light grounds are in the back underneath your hatch latch trim panel. The front grounds are under the hood on or near the radiator core support.
When they do flash, are they slow, fast or just wright?
Old Nov 23, 2008 | 10:22 AM
Mgb86's Avatar
Car: 89 Camaro RS
Engine: Carb'd 350
Axle/Gears: 3.70
The Turn signals seem to work just right when they do work
Old Nov 23, 2008 | 10:28 AM
ACCLR8N's Avatar
I'm thinking the problem is before your flasher if not the flasher itself. A bad ground at the light would effect how long it takes the flasher to heat up and pulse.
Old Nov 23, 2008 | 10:40 AM
Mgb86's Avatar
Car: 89 Camaro RS
Engine: Carb'd 350
Axle/Gears: 3.70
Okay thanks but I think that I have replaced the flasher already so what else could it be?
Old Nov 23, 2008 | 10:47 AM
ACCLR8N's Avatar
A bare spot on one of the positive wires in your steering column or somewhere else going out to the lights. Not a ground. Any chance you damaged the wires from the turn signal switch cramming them back down the steering column when you replaced it?
Old Nov 23, 2008 | 10:50 AM
Mgb86's Avatar
Car: 89 Camaro RS
Engine: Carb'd 350
Axle/Gears: 3.70
i guess thats possilbe I'll take her apart and see what happens Thanks
Old Nov 24, 2008 | 10:51 AM
Mgb86's Avatar
Car: 89 Camaro RS
Engine: Carb'd 350
Axle/Gears: 3.70
Okay so I was wrong the turn signals work just Great when you turn left but when you flick the switch to turn right it starts out fast then gets slower and then blows the fuse
Old Nov 24, 2008 | 06:05 PM
ACCLR8N's Avatar
That could be a bad ground or a funky bulb.
Fronzizzle
Mar 18, 2019 08:29 PM
z28_AJ
Aug 27, 2015 08:59 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
