HELP HAVING GAUGES PROBLEM!!
Old Jan 26, 2010 | 06:34 PM
I_R_O_C_Z_2_8's Avatar
Car: 1991 Trans Am GTA
Engine: 350 tpi
Hi i am having problems with my gauge cluster...i posted awhile back that my battery gauge was not working so i decided to check it out..well it turns out it does work..i took off the spedo and started the car and it went up to the middle line like nothing...but as soon as i put the rpm gauge back in it dropped..so when u would take the rpm gauge off it would be good and when i plugged back in it would drop..And when i turn on the instrument cluster lights everything stops working can anybody tell me what can be going on?
Old Jan 26, 2010 | 07:48 PM
Engine: 350 tpi
Re: HELP HAVING GAUGES PROBLEM!!
maybe there can be a short in the back of the gauge cluster?
Old Jan 27, 2010 | 10:25 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Meter Reader
It sounds like some connection(s) have become faulty, especially ground(s).
Inspect all the connectors and check the connections with a meter.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog or “running” lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime and the nitwits that need headlights for a little rain
Old Jan 27, 2010 | 10:45 AM
Engine: 350 tpi
Re: Meter Reader
And where would the ground be to the gauges i really wanna fix this cause it gets annoying when u cant havethe dash lights on at night?
Old Jan 27, 2010 | 10:58 AM
NINÅ's Avatar
Transmission: 765R4
Meter Reader
The bulk of the grounds are sent to a termination behind the left side of the dash on the ‘convenience center’ bracket.
Happy Racing!
Old Jan 27, 2010 | 12:15 PM
Engine: 350 tpi
Hmm. i found some grounds under where the fuse box is and everything is connected...is that to where u where reffering?
Old Jan 27, 2010 | 12:58 PM
NINÅ's Avatar
Transmission: 765R4
Meter Reader
Sounds like it.
If it’s all good use an ohmmeter between ground and the illumination bus to see if that’s grounded.
Happy Racing!
Old Jan 27, 2010 | 02:39 PM
Engine: 350 tpi
Re: Meter Reader
alright...and quick other question is my lighter suppose to be always hot??cause i hooked a radar up to it and when i turned off my car it stayed on??
Old Jan 27, 2010 | 03:02 PM
NINÅ's Avatar
Transmission: 765R4
Meter Reader
Yes, the lighter socket is always ‘hot’.
Happy Racing!
Old Jan 27, 2010 | 09:32 PM
Engine: 350 tpi
Re: Meter Reader
Checked it it checked out good..and i hooked the lighter up today and it works now i replaced the fog light switch thinking it was that but nope..man
Ghettobird52
Jul 5, 2024 11:18 PM
rocn7roc
Sep 21, 2021 02:16 PM
Infested
May 22, 2018 11:56 PM
db057
Sep 4, 2015 07:57 AM
justin57
Aug 20, 2015 07:05 PM
