I need to bypass the fuse block..
Old May 25, 2010 | 09:07 PM
fermium257's Avatar
Car: 1992 Camaro RS
Engine: 350 TBI
I am the new owner of a 92 Camaro with a 350 recently dropped in. Amongst all the issues this car has from whatever one of the PO's has done.. the one that is on the top of my list is getting the HVAC working. There is no fuse in the fuse block for the blower, and the socket for the fuse is all burned up/melted.
What I need to know is how difficult would it be to bypass the fuse block to get the blower working, at least temporarily, to find out WHY, and/or WHERE the problem is so I can fix it correctly.
Old May 25, 2010 | 09:20 PM
irock88's Avatar
Car: 88 (SOLD) & 90 Iroc convertibles
Engine: 5.0 TPI, 5.0 TPI
Transmission: 5 speed & auto
Axle/Gears: 3.08 & 2.73
Re: I need to bypass the fuse block..
I wouldnt bypass the fuse block to go direct. Check for a short or put wire onto spare fuse(load side) with same rating at least this way if there is an issue the fuse will go.
Old May 25, 2010 | 09:27 PM
Pocket's Avatar
Car: 91 Trans Am
Swap the dash harness with one from a JY thats not so hacked up
Old May 25, 2010 | 09:34 PM
fermium257's Avatar
Car: 1992 Camaro RS
Engine: 350 TBI
See the thing is.. I put a fuse into the socket, and no go. I tried a wire jumper and no go. I'm thinking the contacts are jammed up inside the fuse block somewhere. I need to drop the block down and take a look at it I suppose.
Old May 25, 2010 | 09:35 PM
fermium257's Avatar
Car: 1992 Camaro RS
Engine: 350 TBI
That's not a terribly awful process is it? On a scale of 1 to 10, how hard would that be to do?
Old May 25, 2010 | 09:46 PM
irock88's Avatar
Is it for just that one fuse or others as well
Old May 25, 2010 | 09:49 PM
Pocket's Avatar
Car: 91 Trans Am
1 being air filter, 10 being engine swap, Id rank it a 6.5
Ill tell you from experience, tracing wiring inside a dash harness thats still installed in a dash is significantly more difficult
Old May 25, 2010 | 10:07 PM
fermium257's Avatar
Car: 1992 Camaro RS
Engine: 350 TBI
I'm sure it is. I've really never messed with any wiring inside a car, besides installing a radio or 30, amps, and speakers. I'm not easily intimidated by it.
Old May 25, 2010 | 10:09 PM
fermium257's Avatar
Car: 1992 Camaro RS
Engine: 350 TBI
Just the blower fuse. All the others are just fine surprisingly. There's so many minor annoying things that were done wrong, or not at all. This is going to be a fun project.
Old May 26, 2010 | 12:36 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Drop the block and see if you can get the blower fuse terminals out and just move them to an unmelted open slot.
Old May 26, 2010 | 07:51 AM
fermium257's Avatar
Car: 1992 Camaro RS
Engine: 350 TBI
Brilliant idea. Wish I thought of that! lol
Old May 26, 2010 | 12:36 PM
travis401's Avatar
Car: 91 Camaro RS
My truck decided to melt a couple of fuse slots a while ago. I did the same thing, took me about half an hour.
$750 L98
Feb 1, 2025 02:25 PM
3rd gen money
Oct 11, 2019 09:57 PM
thunder57
Nov 7, 2015 02:28 PM
lanceflame44
Sep 25, 2015 12:28 PM
gta892000
Sep 16, 2015 12:37 AM
