WTF??? Engine will not shut off!
Old May 31, 2010 | 04:02 PM
craig_stan350's Avatar
I did an engine swap and now my engine will not shut off with the key. What did I do?
Old May 31, 2010 | 04:13 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: WTF??? Engine will not shut off!
Wont shut off like it just keeps running like normal, or it sputters and tries to stay running for a few seconds, but eventually shuts down after turning off the key?
Old May 31, 2010 | 08:00 PM
It runs normally affter key is off, i have to dump the clutch in gear to kill it
Old May 31, 2010 | 09:05 PM
travis401's Avatar
Car: 91 Camaro RS
Is it a mechanical pump, or electric? It sounds like you have a mech pump and your distributor wired in to a constant 12v source instead of an IGN 12v source. It should be wired to an IGN 12v source so when you turn the key off, it not longer gets power and the engine dies. If its an electric pump then the only way for it to keep running is if both the dizzy and pump are still receiving power after you turn the key off.
Old May 31, 2010 | 09:57 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
also, if you start it up again and it doesnt shut off, unplug the 12v wire going to the distributer instead of dumping the clutch.
Old May 31, 2010 | 10:02 PM
travis401's Avatar
Car: 91 Camaro RS
Yea, dumping the clutch to kill it is just asking for something to break.
Old May 31, 2010 | 10:04 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
I agree with the "you probably used a constant 12v source" theory.
What wire did you use for the distributor?
Old Jun 1, 2010 | 06:02 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
If it is factory EFI then the fuel pressure switch at rear of block will keep 12V on the pump so long as engine running ( is wired in parallel with the pump relay)
Only way to stop engine is kill Ign
Old Jun 1, 2010 | 01:33 PM
travis401's Avatar
Car: 91 Camaro RS
I forgot about that switch....
Old Jun 1, 2010 | 02:51 PM
Blown84Bird's Avatar
Car: 84 firebird, 85 transam
Engine: 350 SBC Or 7.07 Tonys,305stock
Transmission: Big Ugly, 700r4
Axle/Gears: 4th gen rear disk 3.42 lsd,9 bolt
How about msd box getting feedback from the alt. If its running a box
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
wayshegoes
Aug 17, 2015 12:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Fronzizzle
Aug 9, 2015 01:15 PM
