anything wrong with using 14 guage in place of 16 gauge?
Old Dec 17, 2011 | 08:20 PM
0pyders's Avatar
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
Hey smart people. Tell me why it wouldn't be a good idea to have an alternator pigtail that has a lower gauge wire size than the 2 factory wires that are in my harness (the brown and red one).
Wouldn't I still be ok? I'm thinking that if the wire is just bigger it's not going to be the weak link in the chain. Like a reversed fusible link lol.
Old Dec 17, 2011 | 08:26 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: anything wrong with using 14 guage in place of 16 gauge?
Water flows through a big pipe easier than a small pipe, same with electrons.
Old Dec 17, 2011 | 10:09 PM
0pyders's Avatar
I understand that but the number of electrons flowing should be the same even if bigger wire is used, right?
I just want to know if the red and brown wires that go to my alternator will get damaged if the pigtail I bought that goes to the alternator has a thicker gauge of wire.
Old Dec 17, 2011 | 10:52 PM
red rock's Avatar
Car: 1987 iroc
Your not going to damage the alternator, but what are you hooking up, and why wouldn't you want to go to the battery?
Old Dec 17, 2011 | 11:03 PM
0pyders's Avatar
I'm just trying to replace the connector that goes to my alternator because It's smashed up. The new connector I got has thicker wire than the old one.
Old Dec 17, 2011 | 11:07 PM
red rock's Avatar
Car: 1987 iroc
Then no, that won't hurt anything, in fact, it will be better. Just a note, solder joint with heat shrink is the best connection.
Old Dec 17, 2011 | 11:10 PM
aremy10's Avatar
Car: 91 firebird
Axle/Gears: stock
when in doubt you can go bigger, just not smaller. No problems with using that pigtail. Red rock is right
Old Dec 18, 2011 | 01:03 AM
0pyders's Avatar
Cool glad that works. And yeah I'm going to solder/ heat shrink them.
Thank you for the help.
Old Dec 18, 2011 | 01:23 AM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
I have a CS144 that puts out around 260 or so and I moved my battery to the trunk. I have an electrical block on the passenger fender and I ran car audio wire #4 from the alt lug to the block with a copper lug at the alt. It works off of surface area and the good audio wire has thousands of small copper strands that works perfectly. If a wire is getting warm then go bigger and use better wire. I ran 2 ought back to the battery. I can jump the car from the front or back. All of the car audio stuff is very high quality.
GTAman
Jul 3, 2024 07:29 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Dyno Don
Jan 24, 2016 08:24 AM
TheTraut88
Sep 11, 2015 05:16 AM
andy74
Sep 3, 2015 08:41 AM
