Ideas for kill switches?
Car: 1987 Iroc Z
I am not a very creative guy lol. Just need some ideas on kill switch (hidden) setups to disable the car. These IROC's are bad *** looking cars and easy targets
1 Post
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: Ideas for kill switches?
this is what im using for mine. Plus being keyed its not like you have to hide it
http://www.ebay.ca/itm/300868783408?...84.m1497.l2649
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
A switch grounding the coil Neg terminal with the wire to the switch hidden inside the stock harness makes it almost impossible to hot wire a engine
A switch on the wire to the fuel pump also works
Car: 88 GTA Notchback
Axle/Gears: don't know
what about doing like this:
http://www.ebay.com/itm/RFID-Reader-transponder-key-fob-security-/370631823937?pt=US_Car_Keys_Transponders&hash=item564b60d241#ht_898wt_1399
RFID wired into either your VATS (if it is bypassed), starter, ignition, etc.
wireless and completely concealable.
Engine: 4++,350 & 305 CIs
Pull the ign and fuelpump fuse underhood.
Quick easy and cheap.
Car: 86 Z/28 IROC-Z
Axle/Gears: 9 Bolt 3.27
For starters, we put a chain on the hood. So you cant just reach under and pop it.
We have a cool little switch on the dash for the starter kill. Dont really use it much, as the alarm will cover that.
Have a hidden switch on the fuel pump.
Hidden switch on the Ignition, that also kills the interior lights.
^ use these all the time..
If someone happens to get under the hood. Its all been rewired to seperate the power coming from the drivers side & the ecm coming from the passengers side. < did this after seeing all connections within 5 inchs to start the car.
Also the purple wire for the starter is in place, but it does nothing. A new wire was installed thru stainless steel tubing, have to use a die grinder to cut it.
You can do pretty much what ever you can think of to install for kill switches.....
Had my car since 1986, I look under there sometimes thinking...... how the hell did I wire this
