what is this switch for
Car: 1985 camaro berlinetta
Engine: carb'd lg4 305
Axle/Gears: 3.08's sonn to be 3.73's
what is this switch for on my center console its by the electric window switches it has 2 gray wires and 2 black wires and 1 pink wire with a black stripe heres pictures
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: what is this switch for
I think that switch is for one of these options:
1. Rear Wiper Washer
2. Cruise Control On/Off
3. Fog Lamps
Based on the wire color code, I think it's for the cruise control.
3. Fog Lamps
Car: 1990 Camaro RS
Engine: L31
That's wild, cruise in the console and not on the turn signal lever! It would be easy to tell if it's one of the three, do you have a rear wiper, or fog lights? If yes to either of those then that would be it. If no, it would have to be cruise.
so i have a berlinetta which means my cruise was behind the pod radio but the cruise was removed by PO and i have no rear wiper/ wiper fluid and i have no fog lights
ok so i figured out it was for the cruise control but the PO didnt take out the switch or any of the wires
idk what it was cause my cruise control which was ripped out, i dont have fog lights, and or a rear wiper fluid. so i just took it out and put a switch for an electric fuel pump
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
It's a cruise control plug,.....
84-86 Berlinetta's had a cruise control "ON/OFF" button that was possibly mounted in 2 different locations. Most of them were placed on the "filler panel" behind the radio ( horizontal mounted button ) but some were factory mounted on the top of the center console ( vertically mounted button. )
My Cruise button is on the second row down and on the right.....
Yeah, this seems like one GM didn't totally think through for heavily optioned Berlinettas. That console gets quite cluttered. I looked for images all over because it intrigued me. That cruise button I posted said it was mounted on the console, I didn't think about the spot where the radio would be with no pod.
Here's a pic showing where it was factory mounted on the 84's........ I think it got moved to the middle of the center console starting in late 85. When I converted this car to a stick I had no use for the manual TC lock-up toggle button that was in the middle of the center console and moved the Cruise to that spot to fill the hole.
No - No, Not factory,...... custom wired toggle for TC Lock-up.
I used a factory Berlinetta option button ( just scratched off the script ) as a manual TC lock-up button so that I had an "ON" light when the TC was engaged and to keep the factory "look".
Randomtask2
Sep 10, 2015 08:37 AM
