Stock water temp gauge problem?
Old Jul 28, 2015 | 11:09 AM
SS-EXPRESS's Avatar
Car: 1987 IROC-Z
Engine: 355
Transmission: Stock 700-R4
Axle/Gears: Stock 9-bolt, 3.23
Had a needle sticking on the temp gauge so I took apart the bezel and freed the needle. Turned the ignition to key on but did not start the car and you could see the needle move a bit and settle into the bottom 100 degree part of the gauge so I knew it was getting power. As soon as the car is started the needle instantly pegs. I have a new sensor but haven't tried it yet. That will be my next step but was just wondering what everyone thinks could be causing this? Thanks!
Old Jul 28, 2015 | 02:26 PM
Rockguy's Avatar
Car: 88 IROC-Z
Engine: 5.7 TPI
Re: Stock water temp gauge problem?
I would try the new sensor
Old Jul 28, 2015 | 04:04 PM
Sounds like the wire is disconnected and laying against something metal. (shorted to ground)
Sending unit (not really a "sen-sore" [/mr.spock]) might be fine... try hooking the wire up right.
Old Jul 28, 2015 | 04:57 PM
Rockguy's Avatar
Car: 88 IROC-Z
Engine: 5.7 TPI
I guess I assumed something that simple would have been checked but, you never know.
Old Jul 28, 2015 | 05:23 PM
Did you check it?
Then on what basis did you make this a$$-u-me mistake?
Old Jul 28, 2015 | 05:33 PM
Rockguy's Avatar
Car: 88 IROC-Z
Engine: 5.7 TPI
Did you check it?
Guilty as charged.
Old Jul 28, 2015 | 05:37 PM
Wife'sCar's Avatar
Car: 91 Camaro RS T-Top
Engine: 5.0 Tbi
Old Jul 28, 2015 | 06:04 PM
Mang the smilies are a BEOTCH these daze....
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
rocn7roc
Sep 21, 2021 02:16 PM
Infested
May 22, 2018 11:56 PM
