Best headlights
Old Nov 6, 2019 | 09:19 AM
budget builder's Avatar
Car: 91RS
Engine: carb'd 357 vortec
Axle/Gears: 3.42 posi
Best headlights
Just wondering if thru experience and time if there are any better than the sylvania extra vision???? The best L.E D????
Looking for a lot brighter, more distance, and reliable. I found a write about upgrading wiring harness and cleaning contacts https://www.thirdgen.org/headlightupgrade/
Didnt know if there were name brands or better tech since this article was written. Thx fellas
Old Nov 6, 2019 | 02:37 PM
885speed's Avatar
Car: 1988 Camaro
Engine: LR4
Axle/Gears: 3.23posi/disc
Re: Best headlights
My setup is as follows for low beams(haven't done highs yet since I hardly drive my car anymore)
I'm pretty happy with the light it throws out. Not as bright as it used to be now that the bulbs are like 8 years old, but still a big improvement over those factory style bulbs.
Good quality(forget the brand I bought) metal and glass housings from ebay that allow H4 style bulbs to be used
Headlight harness to draw power directly from the battery.
5000K HID kit(don't skimp on quality with HID or LED bulbs unless you like changing them out often)
Properly aimed the headlights
When I made the harness, I re-pinned the headlight connectors on the car for H4 bulb so that if I had any issue I could just put a regular H4 bulb in the housing. IIRC you swap the ground and the high beam pins, but don't take my word for fact on that part as its been quite a few years since I've done it lol.
Old Nov 6, 2019 | 03:10 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Best headlights
Cibie conversions with Phillips X-Treme Vision bulbs (H4 - low/high; H1 - high) is what I run. The Cibie conversions were discontinued a long time ago; I found some NOS on ebay and at an online seller some years ago. Instead of re-pinning the connector for H4's, I bought a Hella adapter harness from Susquehanna MotorSports (https://www.rallylights.com/hella-ad...ion-lamps.html).
I'm using LED conversion bulbs (9004, 9005/9006) on a couple of my other cars. These are an improvement over tungsten filaments. I'd avoid the bulbs that have four LED "panels" (for lack of a better term) that are 90-degrees to each other. They throw light everywhere it's not needed. Stick with the ones that have two panels that are 180-degrees to one another. Like 855 commented, avoid cheap (ebay) bulbs unless you like replacing them every 24 months or so. I've had some that were bad out of the box. A potential fit problem with these bulbs is they need additional clearance behind them for the box fan. I don't know...the jury is still out.
A good alternative might be those direct fit LED headlights you see on tractor/trailer rigs.
Old Nov 9, 2019 | 11:42 PM
Car: 91RS
Re: Best headlights
Thx fellas
Old Nov 10, 2019 | 12:07 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Best headlights
Sylvania silver stars for the easy plug/play.
Old Nov 10, 2019 | 12:36 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Best headlights
These are with the daytime running light portion on.
My choice for best headlights.
These lights are lightyears ahead of the old 80's style sealed beam and on par with the offerings on new cars. I no longer feel like I'm driving with a flashlight at night with every road sign glaring at me.
These are LED sealed beam units that you can find with a little searching on Amazon or eBay.
Price has come waaaaayyyy down on the LED stuff, so much so that the BMW headlight swap has become a bad option.
Old Nov 11, 2019 | 09:23 PM
Car: 91RS
Re: Best headlights
Tibo, u got any name brands, part numbers?
Is this similar???
https://www.ebay.com/itm/Fit-82-92-C...EAAOSwi5FdTQZT
Old Nov 12, 2019 | 06:50 PM
Car: 91RS
Re: Best headlights
Found these
https://www.summitracing.com/parts/hla-003427291/
Old Nov 13, 2019 | 05:15 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Re: Best headlights
Is this similar???
Those appear to be similar if not the same. Just be mindful if you buy a set that you don't buy the set that has the red daytime running light. Those are illegal to have on while you drive.
Old Nov 14, 2019 | 04:58 AM
Car: 91RS
Re: Best headlights
10-4, thx
Old Nov 14, 2019 | 05:03 AM
Car: 91RS
Re: Best headlights
You would think that by 2019 someone would have started making lights specifically for our cars by now
Old Nov 14, 2019 | 08:43 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Re: Best headlights
These cars have been shunned since the fourthgens debuted, especially once the fourth generation ls1 debuted.
Streetstuff
Mar 12, 2016 04:27 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
aaron7
Sep 26, 2004 08:18 PM
Romco92350z28
May 17, 2003 09:29 AM
