ECM no power?
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
ECM no power?
88 GTA engine and harness. Was running after installing. Set a year or so. No start now. Have a 89 firebird dash and wiring. Didn't turn over with key. So I hooked up remote trigger switch. Starts with fluid. So I have spark. Check fuel pressure. Good! Key in run position.seat belt light and sel. No vats light at all. No power to ECM/crank fuse. There is power to the pink/black wires. Question, where does the ECM/crank fuse get it's power supply from? The only shop manual I have is a 85 Camaro. Can the starter enable relay cause this problem? I don't think the ECM would have power If the fuse isn't getting any. Any leads would help
Axle/Gears: 273?277
Re: ECM no power?
I have checked for injector pulse at the injectors. Keep in mind that I have had the car running after installing the engine and harness,ecm and dash.
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: ECM no power?
89 wiring, does that mean this is a VATS car? If so, you can test if it's VATS getting in your way by bypassing the starter enable relay with a thick wire and 2 male spade connectors. If the car starts cranking, that relay wasn't getting activated (or that relay is no good) and VATS is what controls it. The other thing VATS does is disable the injectors so you might try installing a bypass module if the cranking test is successful and the relay isn't busted.
Axle/Gears: 273?277
Re: ECM no power?
I will do that. But would that keep power from getting to the fuse box on the ECM/crank fuse. There is some power in the box
Axle/Gears: 273?277
Re: ECM no power?
For lunch I did a quick relay bypass. Turn over with the key. More when I get home
Axle/Gears: 273?277
Re: ECM no power?
OK. The fuse I tested yesterday was the crank fuse. That has no power. The ECM fuse only has wiring on one side. That post has power with key on. The injector I have a test light on has no pulse when I turn it over remote. Have not tested at the ECM connectors for pulse.
Axle/Gears: 273?277
Re: ECM no power?
How and where do I get the module? I have not seen any info on where to get them. I will check out AutoZone.
Car: 1989 IROC-Z
Engine: L98 350 TPI
Axle/Gears: 273?277
Re: ECM no power?
I have never bought anything off eBay. I don't buy anything from internet. My wife has a few things from stores. How do you know which frequency if there was never a chip key? Or does it cover all frequency at one time
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: ECM no power?
I think this product is likely too niche to be sold in stores, so you might need to make an online purchase. This is the manufacturer's website for the bypass module, I would consider it less safe than ebay to purchase from as it's not an https website and won't have ebay's purchase protections:
http://timers.shop/GM-VATS-Bypass-Mo...-LT1_p_33.html
These are the instructions for the device:
http://timers.shop/assets/documentat...***_Module.pdf
The module only outputs one frequency at a time, the instructions tell you how to control what it outputs. I believe my '89 needed the 30hz signal so I tied the blue wire into the ground and left the green disconnected. I used an alligator clip to temporarily connect the various wires until I found the combination that started the car.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: ECM no power?
The eBay hz modulator is a great value to bypass vats.
B6 at the ecm is the hz signal to enable injectors.
https://tpiparts.net/1227165_pinout_diagram
Axle/Gears: 273?277
Re: ECM no power?
Thank you all. You have help me out in the past. Your rescuing me again.is the pin the same on all vats third gen
Axle/Gears: 273?277
Re: ECM no power?
By the way. The car I got the dash out of. Was a 89 firebird with 5.0 tb. It was a running car with no chip in the key. I used the complete dash, harness and steering column.
Engine: Lb9
Transmission: M20
Re: ECM no power?
Tpi 88-89 and tbi is b6 1227730 tpi and mpfi 3.1l is f10 for 90-92.
the letters on the chip will identify if from late 88 may contain vats.
Axle/Gears: 273?277
Re: ECM no power?
A few years ago when I did the swap you identified the ECM and prom for early non vats 88 with 5.7 auto 3.27 gears. That is what I have. But the engine harness has the blue wire on,think it was pin 66? ECM prom engine and engine harness all came out of a 88 GTA running. He had already sold the dash harness. That's why I took my dash out and installed the 89. How much is a prom with vats tuned out
Engine: Lb9
Transmission: M20
Re: ECM no power?
Sounds like your set with the prom you have if I identified no vats. You have verified accessory power and constant battery power at ecm ?
Axle/Gears: 273?277
Re: ECM no power?
Power at fuse box. Have not tested at ECM yet. Last night I couldn't get a injector pulse at the number one cylinder injector. I had to use a jump wire on the starter enable relay
Axle/Gears: 273?277
Re: ECM no power?
I'm sorry I'm so difficult. My ECM is 16198259 delco. The prom is akxz3294. The harness dose have a blue wire in the b6 pin. I will be checking for power at the b6 wire with key in run? Or crank
Engine: Lb9
Transmission: M20
Re: ECM no power?
chip code akxz for 88 350tpi automatic.
was released on 05/19/87 and has vats enabled.
if you don’t have a passkey module and resistor probably won’t see a hz signal or 2.5v at ecm for vats.
i was referring to ecm constant power at pin b1 , c16 accessory power at a6.
Axle/Gears: 273?277
Re: ECM no power?
I tested b6 . Nothing. I will go back out and tested the other 2
Axle/Gears: 273?277
Re: ECM no power?
The pass key box was in the dash out of the 89 when I installed it in the 88😂 all this because some previous owner had to take the engine and harness out for what ever reason. But heck! I only paid 700 delivered to my house. Had a boat anchor that wasn't hooked up yet in it too
Axle/Gears: 273?277
Re: ECM no power?
Have power to pins b1 and c16 with key in run. Pin a6 has nothing. Key on or acc.
Engine: Lb9
Transmission: M20
Re: ECM no power?
A6 goes through c207 to fuse box accessory power to power up ecm.
Axle/Gears: 273?277
Re: ECM no power?
How does the ECM fuse work when wires only come out one leg of the fuse? I will re check a6 and follow it up to the 207. Where are the accessory fuse location. I didn't see it in the box. I will see what I can find out
Axle/Gears: 273?277
Re: ECM no power?
Ok. I found the acc. Fuse. It's a big one. Wiggled it and my test light came on.. key in run. Didn't come on in acc setting. Rocky back instead of forward to start. No start and no pulse at injectors. I do have power at the ECM and fuse box. So do I start a new thread or what
Axle/Gears: 273?277
Axle/Gears: 273?277
Engine: Lb9
Transmission: M20
Re: ECM no power?
You can tap into ecm
accessory power and ant ground. I think it’s 30hz signal .
Engine: Lb9
Transmission: M20
Re: ECM no power?
if you choose the chip option send me a pm but modulation module works fine .
Axle/Gears: 273?277
Re: ECM no power?
I ordered one through eBay. Took me a good time to get through it. Supposed to be here by the 19th
Axle/Gears: 273?277
Re: ECM no power?
I waited all this time for module to come in and has no instructions and the website says nothing about the module. I continued to look and there are alot of other people having the same trouble. If it's supposed to be so simple. Why no info on installing it. Help!😑
Engine: Lb9
Transmission: M20
Axle/Gears: 273?277
Re: ECM no power?
Tuneperf. Nothing says it plain and simple.. red wire goes to ignition? Ton of wires go up the column.. does this thing tie to the 2 white wire coming out of the column? Like the red to one and the white to the other and black to ground?
Re: ECM no power?
For anyone that has, or is planning to...
PLEASE do not contact me for GM Key-Codes and VATS Resistor Information, from the GM Database by your VIN.
GM CCA requires that a State DMV check, Drivers License, and Title/ Registration (That are all in your Name) be provided.
Thank you!
Thank you!
Axle/Gears: 273?277
Re: ECM no power?
Takes me forever to read and understand what I have read. Always been slow. Any way. I'm suppose to go to the ECM connectors and plug it in there right? Do I cut the wires? Or tie it to them? 89 firebird 5.7tpi. sorta. Red wire on module to the a6 hot black/pink? Black wire on module to the a12 black ground. And white module wire to the f10?
Engine: Lb9
Transmission: M20
Re: ECM no power?
red can goto a6 of ecm no it connects to ecm not passkey module. White to b6 of ecm
Engine: Lb9
Transmission: M20
Re: ECM no power?
Ecm ground or dash frame. Try grounding blue wire of module and try to start green might be ungrounded.
Axle/Gears: 273?277
Re: ECM no power?
So I don't fry something, do I cut any of the wires? Or just splice into all of them.? B6 is the one I have mostly in mind
Engine: Lb9
Transmission: M20
Re: ECM no power?
Splice wires b6 can be cut or spliced since passkey module is not operating.
Axle/Gears: 273?277
Re: ECM no power?
Thank you very much! I'd rather ask questions and take my time than fry something.
Axle/Gears: 273?277
Re: ECM no power?
Just a word of thanks to everyone who helped me deal with this challenge. Last week I got the module soldered in. Today I pumped 4 gallons of the seafoam gas mixture out of the tank and added 4 gallons of fresh 4.00 a gallon gas in the tank. 1 shot of starting fluid for fun of it and 2 turn's of the key later we have a running 88 formula with a 5.7 Tpi. I think this project has been in the works for over 7 years. Not ready for the road yet. Figure another month. Needs sub frame connectors and original drive shaft installed. Thanks again
