Anyone have part no. for rear hatch light switch?
Old Dec 2, 2022 | 07:25 PM
Johnny Gun's Avatar
Car: '88 GTA
Engine: 355 SBC, AFR 195 heads, Stealth Ram
Or a similar or alternate?
Old Dec 2, 2022 | 07:46 PM
vorteciroc's Avatar
Top Answer: 1
Re: Anyone have part no. for rear hatch light switch?
The Physical Switch?
Reach out to @John in RI he sells both Electrical and Interior Parts for our Cars!
Old Dec 3, 2022 | 06:21 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
That would be P/N 20300493,I have the whole unit if you need one.PM me for info
Old Dec 5, 2022 | 08:04 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
There's a light switch for the rear hatch?
Old Dec 5, 2022 | 02:09 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I've got 1 too,.....
LMK if you can't reach a deal with mantaguy !
Old Dec 5, 2022 | 02:45 PM
91banditt2's Avatar
Engine: 5.7 HSR
Interesting, where is this switch mounted normally, my 91 Firebird doesn’t have this switch.
Old Dec 5, 2022 | 04:26 PM
vorteciroc's Avatar
Top Answer: 1
@91banditt2
The Lamp and Switch Assembly are just above the Cargo/ T-Top Well...
And just below the Latch.
Below is an Image of the Rear most Trim-Panel in the Cargo/ T-Top Well.
The Lamp is on the Left Side of the Image; and the Switch on the Right:
Old Dec 5, 2022 | 08:18 PM
John in RI's Avatar
"Early" cars used a manual switch but "Later" cars used a switch on the PPD motor so the light was 'automatic'. I think the change was somewhere around 90 or so. In my 84 ( manual switch ) I wired it up to my Courtesy Light circuit so the hatch lighting is active whenever the DOME light is on.
Old Dec 5, 2022 | 08:34 PM
vorteciroc's Avatar
Top Answer: 1
I made a similar change in my 87.
With the Switch in the OFF Position... the Light of course remains OFF.
However, if the Switch is in the ON Position... the Light will be OFF... But turn on with the Doors OPEN or the Dome-Light ON.
Urocmyiroc
Interior Parts Wanted
Nov 9, 2022 07:57 PM
Oddball
May 20, 2013 11:09 PM
58mark
Jan 18, 2011 05:09 PM
hwcoll95
Mar 31, 2004 09:15 PM
zee28
Feb 20, 2001 10:42 PM
