C100 connector removal
Old Oct 10, 2024 | 08:19 AM
KCG's Avatar
KCG
Car: 89 IROC
I should have titled "terminal removal" not connector...
Does anyone know if a wire/terminal can be removed from the inside of the car without disassembling the C100 connector on the firewall?
I believe I've found my intermittent power drop to Acc fuse and headlights. You can see black heat marks above the Red wire in G5.
Old Oct 10, 2024 | 08:57 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: C100 connector removal
Yes, you can use a de-pin tool and pull out the terminal. Disconnect the connections from the firewall side first.
Old Oct 10, 2024 | 10:09 AM
exiled350's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 427ci Gen 1 Small Block
Axle/Gears: Strange60 4.10 Eaton Truetrac
You have to remove the TPA (white comb that keeps the terminals from backing out) before trying to depin it. I believe it's possible to get it out from the engine bay side but YMMV.
Old Oct 10, 2024 | 10:18 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Yes! Good catch.
Old Oct 10, 2024 | 11:30 AM
KCG's Avatar
KCG
Car: 89 IROC
ok so the answer is NO then?., I can't depin from the interior side without pulling the engine side first?
Old Oct 10, 2024 | 12:20 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
No you can but you need to disconnect the two main harnessed on the firewall side and slide up the comb shaped retainer. Then you can depin.
Old Oct 10, 2024 | 01:03 PM
exiled350's Avatar
That is correct, the catch is on the engine side and the two halves must be separated to get to it.
Old Oct 10, 2024 | 01:19 PM
69-er's Avatar
Here's a better view of the terminal:
You can see how you will have to probe from the right side of the image above, (Engine side), and bend the tab down to release the terminal.
Old Oct 10, 2024 | 06:23 PM
KCG's Avatar
KCG
Car: 89 IROC
Thanks Guys. I think I understand now. We'll give it a shot!
Old Oct 11, 2024 | 07:05 AM
KCG's Avatar
KCG
Car: 89 IROC
This is a great thread for people needing a visual like myself
https://www.thirdgen.org/forums/elec...al-poster.html
Old Oct 11, 2024 | 04:16 PM
KCG's Avatar
KCG
Car: 89 IROC
Thanks to those who replied. With that and the link above, this wasn't as terrible as I thought it was going to be.
I left the 2 connectors alone on the engine side, only removing the center 1/4" bolt. I did remove the right side grease cover for easier access to the bolt...mostly visual.
Pulled the 2 connectors off together. Then slid the white grid looking terminal lock far enough to get to the bottom row I needed. Used a small jewelers screwdriver and pushed in on top of the terminal to unlock its tang and removed the wire from the interior side.
The terminal didn't look terrible, some heat and some hard grease. So I used some cleaner, a small bristle brush, and reapplied some dielectric grease and put it back together.
So far so good.
Old Oct 11, 2024 | 04:38 PM
69-er's Avatar
Glad you got it. Thanks for linking to the C100 thread. Didn't know about that one.
Austin87FB
Apr 16, 2024 04:34 PM
ill
Feb 23, 2024 07:25 AM
BytePaul
Jun 22, 2021 08:13 AM
t/adreams
Mar 8, 2010 09:16 PM
KYLE87
Sep 16, 2008 06:52 AM
