I need help injectors are not pulsing
Old Dec 12, 2025 | 08:02 PM
Jordfiz1's Avatar
So I bought a 92 Camaro 5 speed with a 3.1 and I didn’t have the key so I did the vats by pass it cranks the fuel pump didn’t work so I replaced it then replaced the fuel filter, fuel injectors and, fuel pressure regulator still didn’t start I then replaced the ignition control module it won’t start off of its own fuel it will pop off with starting fluid but will not run I do have the fuel pump directly wired to a switch under my dash is there anything I’m missing any suggestions on things I missed or messed up please help thank you
Old Dec 12, 2025 | 08:26 PM
92RS-HeritageEd's Avatar
Car: 92 RS / 90 IROC-Z
Engine: 305 / 350
Axle/Gears: Non-Posi / Posi - Both GU2 - 2.73
Re: I need help injectors are not pulsing
I'd prob head back to SQ1 and work forward. Like with the VATS Bypass. Can you elaborate, like you spliced in the resistor, that matches the original Key Resistance Value iirc via the orange wire under the dash? What's the status of the Security Light? Do you have a GMSM where you can observe the proper troubleshooting tree?
Old Dec 12, 2025 | 08:30 PM
Jordfiz1's Avatar
yes so I never had the key so i bought all the resistors and tried them till it worked I have no security light and it cranks no problem I do not have a gmsm I’m not sure what that is to be honest
Old Dec 12, 2025 | 09:01 PM
Engine: 305 / 350
GMSM = General Motors Service Manual. I hope these help!
Old Dec 12, 2025 | 09:15 PM
Jordfiz1's Avatar
Thank you! I noticed at the top it says it’s talk about the 5.0 and the 5.7 I have the 3.1 v6 will the apply for that or does that service manual have anything on the 3.1 thank you
Old Dec 12, 2025 | 09:36 PM
Engine: 305 / 350
In fact I do! Here ya go!
Old Dec 12, 2025 | 09:38 PM
Jordfiz1's Avatar
thank you! I think this is gonna help a lot!
Old Dec 12, 2025 | 09:41 PM
Engine: 305 / 350
Np, Post back if you get stuck & I'm sure one of the fine ThirdGen masters on here will chime in and get you on track! Best of luck!
CamaroZilla
Mar 28, 2012 02:01 PM
avenger21
Jun 28, 2011 12:07 PM
91Z28TTOP
Aug 21, 2005 02:15 PM
bigchief
Jul 13, 2005 01:09 AM
8T8IROC
Southern California Area
35
Jun 22, 2005 11:12 AM
