Need a set of heads for 383 [AR]
Old Mar 5, 2009 | 09:50 PM
tyler92's Avatar
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
Looking for a good set of heads to use on my 383.
Old Mar 5, 2009 | 09:51 PM
r62mcmahon's Avatar
Car: 1989 IROC
Axle/Gears: BORG WARNER /3:70
Re: Need a set of heads for 383 [AR]
afr
Old Mar 5, 2009 | 09:54 PM
tyler92's Avatar
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
I am looking for a used set that somebody would sell. Sorry for not putting that in the original post.I wasn't very clear. Thanks
Old Mar 6, 2009 | 06:55 AM
tyler92's Avatar
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
ttt
Old Mar 6, 2009 | 09:31 AM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Is this a street motor thats running pump gas? What configuration are you running now as far as the engine build. Are the pistons flat tops? How much lift do you need the heads to be good for?
Old Mar 6, 2009 | 09:41 AM
tyler92's Avatar
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
Yes it will running pump gas. Flat Top. I would like the lift to be able to go up to at least .500. I am on a budget. Thanks
Old Mar 6, 2009 | 10:22 AM
wesilva's Avatar
Transmission: 200R4
Ok...then I would specify that the heads have a chamber volume of at least 70cc. Using this compression calculator, a 64cc head volume will put you 10:30 compression. I believe you're at about sea level. That's too much compression for even premium gas unless you really have your tune just perfect.
http://www.kb-silvolite.com/calc.php?action=comp
Now since I don't know exactly what your motor specs are, I generalized. I used 8 cc as the piston volume. This is typical 4 eyebrow pistons. I used a gasket thickness of .040". The gasket bore I plugged in was 4.100" and I'm guessing your bore is 4.030" with a deck clearance of .015". I'm sure your stroke is 3.75". If you plug in 70 in the cylinder head volume, you'll come up with a more reasonable 9.73:1. That would leave out the Vortecs I was going to offer you. They are milled to 62cc.
Old Mar 6, 2009 | 10:25 AM
tyler92's Avatar
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
how much would you want for the vortecs any way? This is going to be a carb motor. It would prolly be to much compression.
Old Mar 9, 2009 | 07:39 AM
tyler92's Avatar
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
Would like to get a set of 64cc vortecs.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
mhatfield 14
Oct 24, 2015 07:48 AM
86White_T/A305
Aug 17, 2015 12:16 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
