Can a 3rd Gen's Engine Cradle be dropped like a 4th Gens?
Old 07-21-2007, 07:45 PM
Arctic White 91 RS's Avatar
Car: 91 RS/ 99 T/A/ 72 Vette/ 02 Z28
Engine: LSx/ Dart400
Transmission: M6/ M6/ TH400/ 4L60E
Axle/Gears: 4.10's / 3.08/ 2.73
On 4th Gen's it's possible to drop the K-member and engine all at once as a unit after the wiring harness etc is disconnected. Can a 3rd Gen have the engine pulled this way?
I would appreciate input.
Thanks.
Old 07-21-2007, 07:52 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Re: Can a 3rd Gen's Engine Cradle be dropped like a 4th Gens?
It's easier to do it from the top, isn't it? But I'd imagine so, But it would be a pain in the ***...
Old 07-21-2007, 09:12 PM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
Thanks.
You will have to undo your struts either up top or at the spindle. If you undo them up top there goes your alignment. Basically itll look like this but with an engine on it:
Youll also have to undo your steering linkage to get it out. And probably cut your front brake lines. Overall, a waste of time when it comes out real easy from the top.
Old 07-22-2007, 12:00 PM
I understand that but when, I do the LS1/A4 swap, the car will be getting a new K-member, new struts and new springs. All of that stuff is being replaced anyway. The brakes front and rear are being switched over to an LS1 set up. The rear end will also be replaced.
For my application, would it be worth dropping the cradle?
I agree for engine only it's a waste of time.
Old 07-22-2007, 07:25 PM
socal's Avatar
Car: 91z,97ws6,98fb,87&90jeep,05 yz250
Engine: 5.0tpi,5.7LT4,5.7LS1,4.2I6,5.7TPI,1
Transmission: t5,4l60e,
when we did ours l98/a4 to ls2/t56 we pulled the motor and trans from the top as well as put the new one in from the top. looking at them both the ls is wider but shorter but i think both will get hung up on the frame around the valve cover area. I wouln'd recomend it
Old 07-22-2007, 09:01 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I'd rather lift a 500 lb engine than a 1500 lb car.
Old 08-06-2007, 07:40 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
to answer your question, yes you can drop the 3rd gen cradle similarly to how you can in 4th gens. The main difference is that the 4th gens have coilovers and the 3rd gens don't. so you have to remove the front springs in your 3rd gen before detaching the k-member from the body. Also, you remove your struts from the strut mounts when removing the springs... the strut mounts can stay installed. The only reason your alignment would change is due to the change in weight from one drivetrain to the other. I can give you a step-by-step if you needed more info than that. Good luck with the project
Old 08-08-2007, 10:52 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
Yep, I had my old K-member out when I did my swap. My main reason was because everything was already out from painting the engine bay and I didnt want to risk scratching anything up. I placed my LS1/T56 on a creeper and slid it under the car then raised it into position. Made it very easy to install as one unit. If the trans is still bolted to the engine they can be a pain to drop from the top on the thirdgens especially if your trying not to scratch anything. Not to mention I installed it with all the acessories still mounted.
Old 08-08-2007, 11:11 PM
hgffrank's Avatar
Car: 83 Trans Am
Engine: LT1 350
Transmission: 5 Speed manual
Axle/Gears: 3.73 10bolt till it breaks
If your replacing the K-member, engine, and suspension then yes it would definitely be worth it as long as the engine clears, which others are saying it will.
1992rs/ss
16
01-28-2016 09:58 PM
redmaroz
08-16-2015 11:40 PM
Eagle223usa
Brakes
08-14-2015 09:24 AM
bradleydeanuhl
08-12-2015 11:48 AM
Elliswon
08-10-2015 12:33 PM
Quick Reply: Can a 3rd Gen's Engine Cradle be dropped like a 4th Gens?
