pull LB9 and T-10 at the same time?
Old Apr 21, 2008 | 10:25 PM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
has it been done? is it possible?
Old Apr 22, 2008 | 12:09 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: pull LB9 and T-10 at the same time?
Its been done but its not recommended. There is very little room in the engine bay to do such a thing. Take the hood off, at least.
Old Apr 22, 2008 | 12:17 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
has it been done? thats how it usually happens.. if you take the trans AND bellhousing off, while supporting the engine with a hoist, it will be easier.. since it will just be up and out.. with the trans on, its tilt, up, forward, tilt, up forward, reverse tilt, up forward, etc.. then you worry about hitting things with the transmission..
its entirely up to you.. having a helper is good.. i pull my motor by myself so i pull her with the trans off and usually install with the trans on.. its easier to put the trans on in the garage than under the car..
good luck
Old Apr 22, 2008 | 07:02 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i installed my 408 with the tko600 attached using a hoist. It just made it, but it worked.
remember to remove the dizzy, or at least the cap. It will give you a little more room and you wont have to worry about breaking it.
Old Apr 22, 2008 | 07:12 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Did it, with a T10, just 2 weeks ago. I just unbolted the trans crossmember from the body and left it on the trans, made it 10x easier! That way, its just up off the motor mounts, and out - no going forward necessary to drop the trans off the crossmember that way - just go up.
Old Apr 22, 2008 | 11:15 PM
that sounds about right. i have all the accesories off the front of the engine and the radiator out too. will it install the same way,Air_Adam?
Old Apr 23, 2008 | 06:32 PM
Air_Adam's Avatar
Originally Posted by vasquezmrysvll
that sounds about right. i have all the accesories off the front of the engine and the radiator out too. will it install the same way, Air_Adam?
I hope so.... I haven't put it back in yet lol. I don't see why it wouldn't though... just have to lift the back of the trans (with x-member on it) with a jack once the engine is sitting on its mounts in the front so you can put the x-member bolts back in. Seems easy enough to me?
I love the fact that the T10 is just tiny compared to the T5 and T56... makes it SOOOO much easier to pull out the motor/trans together compared to the T5/T56.
Old Apr 23, 2008 | 09:03 PM
yanked mine today...slid out like a dream! thanks
Old Apr 27, 2008 | 11:47 PM
it also installs as a unit! very ez
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
gta90
Sep 15, 2015 04:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
