best motor
Old Jan 24, 2001 | 10:13 PM
2FASTZ's Avatar
best motor
what would be the best small block to build with fuel injection (lt-1, ls1, tpi, and a t-56.
383 stroker
377 stroker
396
400
327
302
350
305 335
Old Jan 24, 2001 | 11:34 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
396 isn't a small block it's a big block. 377 isn't a stroker it's a destroked 400.
Best engine? Depends what you want it for and how much you're willing to spend. If you want an every day reliable street engine then a 350 works well. If you want to buzz around on an oval track or road course all day long at 8000 rpm then the 302. Easiest way to build the most HP is 400.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
454 Big Block almost ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Jan 25, 2001 | 06:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Somewhere, sometime in the past few months, someone had bore/stroke #'s to produce a SB 396. Don't recall any details, was surprised to hear it.
Humm, perhaps it was a stroked LS.
Can't remember.
Bad enough there are 434 SBC's out there. Now there's something that sounds like my baby Rat. But weighs 100# less.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, WP 305 heads ported & polished, TBD headers & hi-flow cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
[This message has been edited by five7kid (edited January 25, 2001).]
Old Jan 25, 2001 | 06:21 PM
Remondi2's Avatar
350 block + 400 crank = 377
350 block (bored .30 over) + 400 crank = 383
bigger displacement=more power + torque + $$
small displacement=high rpm with less hassle
stroker= little more power+lots more torque
Old Jan 25, 2001 | 06:56 PM
87RS402's Avatar
Five7Kid,
400 Crank + 350 ( or any other 4.00 inch bore ) Block .095 over = 396cid SB
Can be done with some of the older thick walled castings
Old Jan 25, 2001 | 09:40 PM
89V6toV8's Avatar
There is no answer to your question without knowing the application.
By the way, all the nasty small block 400 motors and it's derivatives are built using Bowtie blocks. The production 400 block just isn't sufficient in terms of durability.
Old Jan 28, 2001 | 05:59 AM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
400 block + 350 crank = 377,good high rev,high hp motor.They came in the original Gran Sport Corvettes
Steve
TTA#124-129,bone stock.Cloth/T-Top Festival car
TTA#850,bone stock,best 13.68@100
TTA#861(almost sold),near stock,best 11.99@112.26
TGTA#01,nowhere near stock,9's or bust
Pics and info on My Cars
TTA850@TurboBuicks.com
Old Jan 28, 2001 | 06:03 AM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
Is the car a stick or auto?If it is a stick,I would build a 302(350 block with a 283 crank,3" stroke).Lots of hp potential and rpms,would make a real fun road car.If it's an auto,I'd go with a 406 in a heartbeat.Like the saying says,there's no replacement for displacement....even though I've found one for my GTA
Old Feb 11, 2001 | 02:07 AM
woody86's Avatar
a 396 is a 4.00 bore and a 3.875 stroke.
Old Feb 11, 2001 | 03:04 PM
zerogsx's Avatar
I've always been partial to the 327 for same qualities as the 302. high revs, high hp, plenty of torque, just a good powerband!
Old Feb 11, 2001 | 10:15 PM
RARE-ROC-Z's Avatar
ok guys i got a question.. 350 + 305 crank = what? i know the 350+283=302 but what about 305 crank. little more stroke and still rev the daylights out of it. what would that do. and would i need a 4 bolt block instead on the original 2 bolt and i plan on putting a T56 in this summer if not earlier. thanks all. and get back to me. i will be using a MR from TPIS. thanks again.
1990 IROC-Z L98 350 TPI
AFPR 49PSI, GUTTED AIR BOXES, K&N, RAM AIR, PORTED PLENUM, B&M SHIFTER, 3.23 LIMITED SLIP, DUAL CATS, STOCK SUPER TURBO EXHAUST, COOPER COBRA XST's
MUSTANGS...ONLY 4 LUGS....HAHA THAT IS HILARIOUS.
Old Feb 12, 2001 | 11:12 AM
zerogauge's Avatar
i believe 305 and 350 crank is the same. could be wrong.
Old Feb 12, 2001 | 03:30 PM
85350TX's Avatar
302 is a 327 block with 283 crank. Just get a 383 great street engine tons of torque very responsive motor
hydrolic144
Sep 8, 2015 06:55 PM
masonta
Sep 1, 2015 06:40 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
slade5612
Aug 11, 2015 07:19 PM
