Help Needed! Any experience with LT4 hot cam?
Old Mar 4, 2010 | 02:12 PM
Camaroman83z's Avatar
Car: 1983 Camaro z/28
Engine: zz430
hey all,
I have a fast burn 385 crate engine in my car at this time. I am hinging on the 12's in the quarter and am looking for some extra power. I have been hearing that a huge upgrade for the 385 is the Hot Cam Kit (new cam, springs, retainers, rockers.. etc) Anyone have experience with the lt4 cam? Opinions welcome!
Joe
Old Mar 11, 2010 | 06:53 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: Help Needed! Any experience with LT4 hot cam?
I have used the Lt4 hot cam on many engines combos and they all ran very well.. You plan on using a stroker and i would at that point suggest using a custom grind suggested by http://www.advancedinduction.com/
The Lt4 hot cam is not the cam for a stroker
Old Mar 12, 2010 | 07:43 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Putting the LT4 HOT cam kit in the FastBurn 385 is a sure way to get to 420 hp. Ignore the clown who thinks you have a 385-cube stroker. Switch to an RPM AirGap Vortec and you'll be over 430 horses. To that clown, the 385 refers to the 385 hp rating.
Old Mar 20, 2010 | 06:56 AM
Ilike2stroke383's Avatar
Car: 1987 Gta Trans Am
Engine: 383 Stroker
Transmission: t-56
Axle/Gears: 3.47 02 SS rear end
You shouldnt be calling someone a clown.
Old Mar 22, 2010 | 11:03 PM
89RSTBI's Avatar
Car: 89 RS, 93 Z28
Engine: Vortec 350 TBI, Lt1 6 Speed
not trying to hijack the thread but do you need a canister to hook the brake booster to if you use the LT4 Hot Cam in a Vortec 350? Or will it create enough vacuum to just hook it to the intake?
Old Mar 23, 2010 | 06:10 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
It has plenty of vac in my motor for the brakes
Old Mar 23, 2010 | 07:03 AM
Engine: 383 Stroker
Transmission: t-56
How much vacuum do you even need for the booster? Im only getting about 14 with my cam. But its not a lt4 cam its a lil bigger
Old Mar 23, 2010 | 07:06 AM
3rdgenmaro's Avatar
Car: 88 IROC
dont know. I just know I dont have problems. I couldnt even tell you right now how much mine pulls.
My s10 however doesnt pull enough.
Old Mar 23, 2010 | 08:12 AM
Engine: zz430
I was told 10-11 lbs of vacuum was enough to properly operate the power brakes. BTW hot cam kit was ordered and should be at my door tomorrow. Gentlemen on the phone at jegs said it will be an easy 435 hp. Im pretty pumped.
Old Mar 23, 2010 | 09:59 AM
3rdgenmaro's Avatar
Car: 88 IROC
just remember that you will probably need to drive the timing gear dowl in alittle bit. They stick out further on the LT motors. Not hard to do.
Old Mar 23, 2010 | 12:51 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
i love my lt4 hotcam just need my afr heads to go with it....
Old Mar 24, 2010 | 03:41 AM
89RSTBI's Avatar
Car: 89 RS, 93 Z28
Thanks, that was one thing I was worried about that I now know will not be a problem
IROCZ1989
Jan 24, 2016 03:55 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
Fronzizzle
Aug 9, 2015 01:15 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
