stroker oil pan??
Old Dec 29, 2010 | 04:19 PM
robbyk85's Avatar
Car: 85 iroc
Engine: 383
stroker oil pan??
Hi everyone. Im looking to buy a stroker oil pan for my 383 roller block. I cant seem to find anything for a 1pc main. Is a stroker pan even called for? Any help would be great. Thanks
Old Dec 29, 2010 | 04:33 PM
unobetr's Avatar
Car: 1984 Z28
Engine: 383 stroker
Transmission: th350
Axle/Gears: 3:43
Re: stroker oil pan??
it should be the same as a regular i have the normal oilpan from a 350 on my 383 and it works fine
Old Dec 29, 2010 | 04:39 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Check your clearance. Chances are you'll be fine with a stock pan.
Old Dec 30, 2010 | 04:18 PM
robbyk85's Avatar
Car: 85 iroc
Engine: 383
That would be great if I had a stock pan but I started this build with a 383 bare block, either way I need to buy one. I was thinking something along the lines of a moroso street/strip pan. Are guys running them on thirdgens?
Old Dec 30, 2010 | 05:25 PM
white gold 88's Avatar
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
I got a steel stock style pan for a 400 from Summit on my 2pcRMS block with stroker crank and stock rods. Worked fine on mine.
Old Dec 31, 2010 | 07:06 AM
AutoRoc's Avatar
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
Canton makes a nice one . I have the 2 piece seal version and my friend has the 1 piece version. It's called the 82-92 body road race pan. It runs about $360 on cantons site. Goodluck.
Old Dec 31, 2010 | 01:03 PM
unobetr's Avatar
Car: 1984 Z28
Engine: 383 stroker
Transmission: th350
Axle/Gears: 3:43
my uncle and i both have 2prms and we both have just stockys man his is a 12 sec car and i havnt ran mine yet
Old Dec 31, 2010 | 01:25 PM
MotorMouth's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Unless you run bigger rods like H-beam or want to use a windage tray you can get by with a stock pan.
Old Dec 31, 2010 | 01:28 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Even H-beams might clear. I have Eagle 5700B3D's and I didn't have trouble with a stock pan. YMMV.
Old Dec 31, 2010 | 07:12 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
SCAT H beams on my 383 ( 1 pce ) and stock pan
If anything the H Beams clear better because of the smaller head cap screws they use
Also have full length Moroso tray ; just adjusted tray height on the ARP threaded mounting studs to give air gap clearance from crank throws
Old Jan 1, 2011 | 09:58 AM
robbyk85's Avatar
Car: 85 iroc
Engine: 383
Yes.. thats what Im lookin for. http://www.cantonracingproducts.com/...on&key=15-244T And yep Ill be using 6in. H-beam rods. For $360 it would be really cool if it came with the pump/pickup.
Old Jan 1, 2011 | 03:49 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
have run a few diff 383s. canton makes a few pans that are under $210 from summit 6qt kick out styl that fit the 82/92 camaro
Milodon also makes a few that fit.
the price is also under $210
all are made to fit 1 piece and made to fit 2 piece (diff part #)
you can also pick out the dip stick side.
the thing to remember is know what block your going to use first.
expl: i have one for sale now. the new 427 is way to big to fit the Milodon pan that was on the last 383.
Milodon pan 2 pc main pasng side dip stick 7QT.side kick out. lots of grnd clearance
Milodon oil pump pick
Milodon windage try
Milodon main bolts for windage try.
this set was on a lingenfelter stage 5 383. in my 92 Z28.
was posted a few months back Cheap! less then 1/2 price.
Old Jan 3, 2011 | 06:23 PM
robbyk85's Avatar
Car: 85 iroc
Engine: 383
What do you guys think? This pan should do the trick. http://www.summitracing.com/parts/CTR-15-244T/All/
Old Jan 3, 2011 | 06:49 PM
robbyk85's Avatar
Car: 85 iroc
Engine: 383
One more thing.. Is a 5qt pan to small for a high rev 383?
Old Jan 3, 2011 | 07:01 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
You want 15-244T for a thirdgen.
Old Jan 3, 2011 | 07:12 PM
robbyk85's Avatar
Car: 85 iroc
Engine: 383
Or something close to it. Is this not a good setup?
Old Jan 7, 2011 | 01:28 PM
robbyk85's Avatar
Car: 85 iroc
Engine: 383
Anyone with a good anwser?
Old Jan 7, 2011 | 09:48 PM
AutoRoc's Avatar
Transmission: 4L65E
That's the pan I use. Works good.
My engine was a stock block, 3.875" eagle 4340 and 6" eagle h beams. I wish I got it for $300.. haha.
Oh and once you have a filter filled, you have 6 quarts total. I spun mine to 7500rpm. I also used The Canton pickup and a melling high volume pump. I never seen oil pressure drop, even while slamming the brakes at 140mph after the stripe.
BDR
Nov 7, 2015 03:05 PM
abray1
Sep 14, 2015 08:18 AM
timonator
Sep 13, 2015 11:49 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
