passing emissons with a 355 swap?
Old Jun 3, 2012 | 01:10 AM
nowerelsetoroam's Avatar
Car: 85 camaro
Engine: 5.7
Transmission: th400
Axle/Gears: 4.10
So the camaro I purchased originallly came with a 2.8 fuel injection engine.
Of course I took that out to swap it for a carbed 355. Which here in Colorado won't pass
My swap I'd is almost finished.
But emissions is A problem. How could I make this pass emissions?
I've been told that I could get the tbi parts such as the carb, intake manifold. and ecu.
Will this work? Other then that what other parts do I need?
Can I use the pump the v6 came with?
what other options do I have?
Im open to any options to get this car street legal.
Could any of you members help me come up with a shopping
List of parts I need To make work.
Any input would be very much appreciated!!
Old Jun 3, 2012 | 12:18 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: passing emissons with a 355 swap?
There are 4 options: (1) Use a 2.8 for inspection, use your 355 the other 364 days. (2) Make it a TPI. (3) Make it a ZZ4, per this: http://arb.ca.gov/msprog/aftermkt/devices/eo/D-278.pdf (4) register it somewhere else, keep it garaged EVERY night.
Old Jun 3, 2012 | 05:29 PM
Car: 85 camaro
Engine: 5.7
Transmission: th400
Axle/Gears: 4.10
I got rid of the 2.8 so I'm screwed with that.
But what's the difference between tuned port injection and
Throttle body injection? Isn't tbi cheaper?
I could try to register it somewere else. Just don't know who
To ask for there adress.
Old Jun 3, 2012 | 06:34 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Since when does the EPA care what's cheaper for you? They only care what's cleaner. Sure, some Police Caprices had the LO5, but a caprice is in a bigger heavier category. You might get away with it, you might not. Seriously, far cheaper to go spend $200 on another used 2.8 than to do TPI or fake a ZZ3.
Old Jun 3, 2012 | 11:48 PM
Car: 85 camaro
Engine: 5.7
Transmission: th400
Axle/Gears: 4.10
Damn. Well I wouldnt mind keeping a tpo all the time. I think that would be pretty neat...
Old Jun 4, 2012 | 03:49 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You could also use a computer controlled carb setup. That would probably be the easiest. That would require a computer carb and distributor, computer harness, computer, MAP and BARO sensors, EGR spreadbore intake manifold (I have two if you're interested), EGR valve, EGR valve solenoid, snorkel air cleaner with the thermovac system, cat on the exhaust. You may or may not be able to get by without the A.I.R. system (technically, you can't).
If you put on a mechanical fuel pump for the '85 V8 application, it will include a return that would allow the V6 in tank electric fuel pump to be used. That isn't an emissions issue, though.
Old Jun 4, 2012 | 03:56 PM
five7kid's Avatar
Both the Camaro and Caprice are categorized as passenger cars.
Old Jun 4, 2012 | 04:01 PM
Car: 85 camaro
Engine: 5.7
Transmission: th400
Axle/Gears: 4.10
What's the A.I.R system?
But by doing this would I be able to pass emissions?
If yes. You think you can help me out a bit lol?
I'm lost with computers.
Old Jun 4, 2012 | 05:37 PM
five7kid's Avatar
Air Injection Reaction. aka, "smog pump".
85's came with computer carbs V8's. '85 Caprices came with computer carb 350s. If you can find a Caprice with a complete system, it would have everything you need.
Are you using factory exhaust manifolds, or headers?
My Berlinetta #1 was a factory V6 car. I found an '86 LG4 donor car and swapped everything over to it. When I went for the emissions test & inspection, they just scanned the VIN and looked for the equipment the machine told them it should have (it had all of those things). 2 years later, I changed the heads & cam, added headers, and it passed again. After that I swapped a 350 shortblock (happened to be a ZZ3) into it with the other things the same. I had collector plates by then, so didn't have to pass emissions anymore. I'm confident it would have passed, though.
Old Jun 4, 2012 | 07:19 PM
Car: 85 camaro
Engine: 5.7
Transmission: th400
Axle/Gears: 4.10
I'd be using stock manifolds for the meanwhile. And damn that sounds like a lot
For emissions. I feel like I'm never going to get this car to be street legal.
Old Jun 4, 2012 | 11:00 PM
five7kid's Avatar
My son got his 2001 Blazer with LS1 clone, long tube headers, lumpity cam, universal cats to pass. I never thought it would, but it did.
Old Jun 6, 2012 | 04:48 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I already listed the fake-ZZ3 option.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
By Colorado DMV?
Old Jun 6, 2012 | 03:47 PM
five7kid's Avatar
Yes, and by the Feds as well.
Chuck84TA
Jul 15, 2016 09:05 PM
Reddeath210
Oct 6, 2015 08:20 AM
theurge
Aug 21, 2015 12:46 PM
355tpipickup
Aug 13, 2015 07:35 AM
