motor wont line up for install
Car: 86 t/a
Engine: lg4 305 carbed
Transmission: 700r4 auto
Axle/Gears: stock 2.73
Hey everone. Im putting my engine back in my t/a. Yes lg4. I just have the chain no adaptor on hoist. So pan hits cross member. How do i get the motor mounts to line up. Hoist wont go back far enough. Trans is attached still. Pulled the together no prob but now cant get back in.
Car: 1984 Trans Am
Engine: 355
Axle/Gears: 10 Bolt, Torsen Diff, 3.73's
Re: motor wont line up for install
I'm assuming you're saying that the engine hoist is hitting on the nose of the car before the engine is lined up where it needs to go. If that's the case, you have to go in from the side with the hoise. I had to do it with mine.
If you're saying the motor mounts don't line up, you may have flipped them left to right.
Car: 1988 Camaro
Yeah unless you have a long boom hoist, it will hit bumper of car before you get engine all the way back.
Move the hoist to the side of car. Jack up front of car alittle so hoist legs will go under car, and just install engine from the side.
Car: 86 t/a
Awesome. thanks guys. Yes hoist hits front bumper and wont go back far enough. Ill move to the side of car tomorrow.
Car: 1988 Camaro
Yep that's a PITA and happens on most of all the long front end cars like camaros, firebirds (second and third gens) , corvettes, the older monte carlos, etc.
Back before I bought an extended boom hoist, I got so fed up with the hoist hitting bumpers, I welded in a length of rectangle tube to make my boom longer as most of the cars I would putting engines in was long front end cars.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I'll admit it; on a couple old hoists I've drilled an extra hole closer to the end of the boom. ( and was always sure to strip the motor bare to 'lighten the load' BEFORE pulling it ! )
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Car: 86 t/a
Thanks for the help guys. I moved the hoist to the side of the car. IT was alot eaiser. Engines sitting in car unbolted. Its raining today so cant do much with it today.
84z96L31vortec
Aug 20, 2017 12:16 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
