92 305 tpi for an 87 350 corvette tpi.
Old Oct 24, 2015 | 02:30 PM
jaridjohn's Avatar
Car: 92 z28 convertible
Engine: 305 tpi
Axle/Gears: 2.73 to1
As the title says. I may have come across an 87 tpi 350 . What would the swap involve. Would this bolt right up. Will I need the corvette harness and the computer or will my 305 one work??? Is there casting numbers to look at to ensure I'm not buying a 305 with corvette valve covers on it.. also what will I have to change for certain on the engine ( water neck? Accessory drive? Oil pan?) Any help will be muchley appreciated
thanks guys
Old Oct 25, 2015 | 05:14 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: 92 305 tpi for an 87 350 corvette tpi.
Are you swapping it into a 305 TPI car? 86-91 corvette motors have aluminum heads and the block will have 5.7 cast into it behind the driverside head
Old Oct 25, 2015 | 08:21 PM
jaridjohn's Avatar
Engine: 305 tpi
Yes into a
305 tpi car.
Old Oct 25, 2015 | 09:30 PM
TTOP350's Avatar
You can strip it down to the motor (intake, heads and block). Most of the 305 accessories will be used.
Will need to swap oil pans, exhaust manifolds,fuel rails and get a 350 chip and ESC module.
EGR will need to be addressed if you need to be E-compliant.
will need to drill/tap a hole in the pass head for the serp bracket.
Basically, make the vet motor look like the one you are taking out.
That's some of it.
Old Oct 25, 2015 | 09:42 PM
jaridjohn's Avatar
Engine: 305 tpi
That's some of it.
They are advertising cast iron heads ... fingers crossed it's an upgrade? I plan on rebuilding it anyways ... hopefully it's a set of vortec s with a new intake manifold. But I seen the picks of it it has the nice metal center bolt corvette valve covers.
Old Oct 25, 2015 | 10:17 PM
bigal55's Avatar
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
Vortecs use center bolt valve covers. If they say it is a corvette motor and has iron heads, the only year for that configuration was 86, I believe. Corvette aluminum heads have no EGR provision and used a special manifold base that used an external EGR plumbed from the exhaust manifold so this would be an indicator of a vette motor. If you plan to rebuild it anyway, what difference does it make if it's a vette L98 or an F-body L98 beside maybe using the aluminum heads?
Old Oct 26, 2015 | 07:54 PM
jaridjohn's Avatar
Engine: 305 tpi
you are correct it is an 86. i got the engine and the computer. (minus the harness) they litterally cut this engine out of the car.
Old Oct 26, 2015 | 11:05 PM
bigal55's Avatar
Car: 88 convertible
Engine: 5.7L
Axle/Gears: 3.07
Hopefully it is a vette motor as the 86 vette had a roller cam setup, the F-body didn't get a roller cam until 87. Either way it looks like you got a good one and when you rebuild it, you get to build it the way you want. Starting with a good base is never a bad idea! GL!
Old Oct 27, 2015 | 09:27 AM
TTOP350's Avatar
I just sold a late 86 vet aluminum head motor that was not a roller block, 1 piece rear seal tho.
Still had all the VIN stuff on the pad too.
Old Oct 28, 2015 | 11:24 AM
bigal55's Avatar
Car: 88 convertible
Engine: 5.7L
Axle/Gears: 3.07
With the change over and parts being shared across the different divisions, the early years probably had a bunch of different "undocumented" combinations. I could be wrong on the roller block info but the vette usually got the good parts sooner than the other models. I changed a cam in my nephews 87 Iroc and the speed shop gave him a flat tappet cam. When I took the cam out, it was a roller, he had to get it exchanged and his car was down for a few extra days. Maybe 87 was the changeover year.
Old Oct 28, 2015 | 03:14 PM
TTOP350's Avatar
Oh yeah, lots of weird things happen when new parts are introduced and old ones are being used up.
Did you know some of the last TPI motors in 92 got the PM rods and lighter hyper pistons? Look for black valve covers on late 92 TPIs 305 and 350s. ;-)
Old Oct 28, 2015 | 05:08 PM
F-body-fan's Avatar
I know both 86 & 87 vette convertibles had aluminum heads. Used to have one years ago.
Old Oct 28, 2015 | 08:17 PM
TTOP350's Avatar
Yup, late 86,verts only, got the 128s and all 87s got 128s then the 88-91 got the better exhaust ports from the 113s.
Old Oct 29, 2015 | 03:34 AM
bigal55's Avatar
Car: 88 convertible
Engine: 5.7L
Axle/Gears: 3.07
That's a good bit of info to know when scouring for gen 1 motors!
BDR
Nov 7, 2015 03:05 PM
abray1
Sep 14, 2015 08:18 AM
355tpipickup
Sep 13, 2015 11:35 PM
timonator
Sep 13, 2015 11:49 AM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
