bmr k member work with blackheart trans mount
Old Jul 20, 2018 | 07:51 PM
fbodymn's Avatar
Car: 1988 trans am
Engine: 5.3 lm7
Transmission: 4l60e
Axle/Gears: 4th gen rear 3.42
Does any one know if the k member will match up with the trans mount. I have all the parts just don't want any surprises going together.
Old Jul 22, 2018 | 02:53 PM
alan91z28's Avatar
COTM Editor
Car: 91/89/85/82 Z28s, 88 TA, 88/88 SC
Engine: SBC and LS variations
Re: bmr k member work with blackheart trans mount
to use the holley cross member you need to have the engine move forward slightly. i have used the bmr x-member at one point and that cross member seemed to move the ls engine higher and to the rear which would be a problem
i have used the holley x-member successfully with the UMI k member although i did modify the bolt on engine mount slightly
Old Jul 22, 2018 | 05:49 PM
toddoky's Avatar
I would be surprised if you didn't experience compatibility issues with that parts combination since the Hooker crossmember was designed to work specifically with the Hooker engine mounting brackets, which are the only mounting brackets I'm aware of that move the engine/trans mating plane forward in the chassis slightly like GM did when they put the LS engine in the 4th-gen F-body.
Old Jul 24, 2018 | 04:46 PM
fbodymn's Avatar
Car: 1988 trans am
Engine: 5.3 lm7
Transmission: 4l60e
Well iv put thought into it an the mount and adapter are slotted so there is wiggle room, If there is an issue with the engine being to far back i could try the 4l80e adapter which is longer.
Also having a custom adapter made wouldn't be that hard.
Old Jul 24, 2018 | 05:14 PM
toddoky's Avatar
Yes, the fact that you are using a 4L80 will give you leeway that is not available to T56 users since the case of that transmission extends below the crossmember and is only about 1/2” away from the crossbeam when using the Hooker engine mounting brackets. You may get a there.
Old Jul 25, 2018 | 09:09 PM
alan91z28's Avatar
COTM Editor
you can definitely do it with a T-56... here is how I went about it with a UMI K Member, LS3 and T-56 magnum with a 4th gen tail housing and even used a UMI tubular torque arm...
https://www.thirdgen.org/forums/ltx-...-ls3-swap.html
yes you need to make sure the engine is moved forward. relatively easy to do with the UMI as you can adjust the motor position with the motor mount adapters that bolt to the overall UMI k member
it has really worked great and is a blast to drive. no body contact, etc of the transmission, engine, exhaust with this set-up.
I now have one in process using a SBC / LT1 T56 with UMI K member and again am using the Holley cross member. I have everything all mounted in the car and only needed to slightly lengthen the holley trans mount slots to get it to work (ie on the SBC you don't have the adapter plate to k member like on the LS so after getting everything in place I just adapted slightly the holley piece in this instance
Old Jul 26, 2018 | 05:15 AM
toddoky's Avatar
As you have noted, the ability of the Hooker transmission crossmember to work with engine mounts other than the Hooker mounts it was designed with is fully dependent on the fore/aft engine position provided by the specific mounts in question. If they are designed to locate the engine/transmission mating plane in the stock SB location only, then they will not be compatible with the Hooker crossmember. I'm glad it worked out for you.
Old Sep 3, 2018 | 09:59 PM
fbodymn's Avatar
Car: 1988 trans am
Engine: 5.3 lm7
Transmission: 4l60e
I'm at the point of finishing up the install, tomorrow I'm going to have a custom adapter made to go from the trans to the crossmember with the bmr k-member and a 4l60e the bolts for the mount pad land right in front of the crossmember about an inch back and a half inch higher then the supplied 4l60e adapter. so basically the same shape minus the drop down with the bolt holes closer to the trans mount, the drive line angle still looks good but my big question is how to reuse the factory torque arm as there is no such mount on a 4l60e and the stock clam shell does not fit. Holly has no info about the torque arm situation.
Old Sep 3, 2018 | 10:13 PM
fbodymn's Avatar
Car: 1988 trans am
Engine: 5.3 lm7
Transmission: 4l60e
Maybe this is what i need. https://ls1tech.com/forums/parts-cla...arm-mount.html
Old Sep 3, 2018 | 10:18 PM
fbodymn's Avatar
Car: 1988 trans am
Engine: 5.3 lm7
Transmission: 4l60e
Found this 6 bolt version. https://www.ebay.com/itm/4L60E-Exten...-/112574980944
I'm going to bolt in the stock crossmember to see how far off i am from the stock location.
Old Sep 4, 2018 | 06:19 AM
toddoky's Avatar
Is there a reason you can’t use the torque arm mount bracket that is welded to the Hooker crossmember and the included hat bracket? It is there so you can divorce the arm from the transmission.
Old Sep 4, 2018 | 04:14 PM
fbodymn's Avatar
Car: 1988 trans am
Engine: 5.3 lm7
Transmission: 4l60e
The crossmember I got didn't come with the bracket, the square part calling holly.
Old Sep 8, 2018 | 11:26 PM
fbodymn's Avatar
Car: 1988 trans am
Engine: 5.3 lm7
Transmission: 4l60e
Did you have trouble with space between the engine and hvac box because I don't have room to mount coils. Or is the problem with the bmr unit?
Old Sep 9, 2018 | 08:12 AM
toddoky's Avatar
There’s no clearance issue when using the Hooker engine mounting brackets, so I assume your engine brackets position the engine further back.
Old Sep 9, 2018 | 05:05 PM
fbodymn's Avatar
Car: 1988 trans am
Engine: 5.3 lm7
Transmission: 4l60e
I have the transmission mount sorted out what i'm wondering is if anyone else has used the bmr ls k member because the space issue is being caused by the k member, nothing hooker related.
Old Sep 10, 2018 | 10:56 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Post #278
https://www.thirdgen.org/forums/ltx-...ml#post5901869
86Base
May 3, 2020 08:32 PM
COSPEED
Sponsored Vendors
Dec 8, 2017 02:26 PM
Alice89
LSX and LTX Parts
Feb 23, 2017 09:55 PM
COSPEED
Sponsored Vendors
Nov 21, 2016 05:19 AM
overdriv
Oct 9, 2011 09:08 PM
