stall/ cam combo
Old Mar 14, 2002 | 04:16 AM
Harley83's Avatar
stall/ cam combo
what type of stall would you guys recommend for a 234 in. @50 244 ex.@50 with 3.73 rear end with 700r-4.. maybe something to the liking of a b&m 2400 holeshot??? or something a little more beefier
Old Mar 14, 2002 | 10:58 AM
Joshua Leslie's Avatar
that cams seemms pretty big, even for a 350. its not very streetable, id say go with a 2000stall and a comp cams x/e 268.
Old Mar 14, 2002 | 12:02 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
10 inch 3000 stall or higher.
Old Mar 15, 2002 | 02:49 AM
Harley83's Avatar
do yall think i would benefit with a smaller cam like the comp cams and a 2000 stall.. i still wanna achieve mid 13's with the 3.73's any advice is greatly appreciated
Old Mar 15, 2002 | 03:19 AM
Harley83's Avatar
im sorry guys ive been hittin the pipe pretty hard tonight... i meant high 12's maybe low 13's... heres what im planning 350 1.94 1.50's 9:5 to 1 compression performer RPM intake 750 carb.. 700R-4 3.73's i just need to find a decent stall/ cam combo to match this.. thanks to anyone for helping...
Old Mar 18, 2002 | 10:01 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
Daily driver? You wont like a ton of stall. 224/234 @ .050 to a 350 is very mild, almost not noticable. unless its like a 108 LCA.
Around there is fine for like 2500 Stall. Go over 2800 Stall and you will be sorry on the street. car would idle smoothly @ 650 RPMS in gear with a 224/234 @ .050 -LCA @ 114
or
224/234 @ .050 -LCA @ 110 = Car will idle pretty smooth @ 800 RPMS in gear.
This is my experience with blazer cams and a mild 355.
234/244 @ .050 (Performer RPM Camshaft)LCA @ 110 Is pretty rough/cool/big/revving car idles around 1000 RPMS / 950 In gear. Nice cam for the street if you dont have emmisions, but pretty big/needs 2800 RPM + Stall.
i would stick with a lower stall for the street, 2800-3000 For the track, if track only.
Old Mar 19, 2002 | 08:24 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Your supposed to match the cams powerband with the convertor, i.e. when the cam comes on. I'm using a 3500 stall, and it's fine for the street.
Old Mar 19, 2002 | 12:30 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
<b>I'm using a 3500 stall, and it's fine for the street.
</b>
Is it a lockup converter? lockup makes it OK for the street since when you want to you can remove the stall. if the application is for a NON-lockup converter, it will be a sorry gas mileage deal when it comes to the street. this from personal experience however... what was your gas mileage affect when you installed the converter?
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
Jorlain
Oct 8, 2015 01:57 AM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
masonta
Sep 1, 2015 06:40 PM
