header advice on install
Old Feb 8, 2003 | 11:40 PM
92rsv8's Avatar
Car: 1992 camaro rs 97 yoyota camry
Engine: lo3 carbed
Transmission: t 5
well since the search engine is down!!! i have been installing my headers...or i should say destalling my exhaust manifolds...
anyway it took me forever to get the passengerside on off!!!!
i have only 3 or 4 bolts to go on the drivers side!!! one of my biggest problems is one of the y pipe bolts stripped and the socket keeps sliding off!!! very agervating!!! i also had to destroy most of the air system because they would not unscrew and all all the wrenches i tried kept sliding off and messing up the heads of the bolts. oh well i wasn't going to reuse it anyway!!! well if anyone has any good install tips for me i would apreciate it!!
chris
Old Feb 9, 2003 | 06:32 AM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
sears has an offset swivel head 3/8 drive ratched, it will make access awsome.
Old Feb 11, 2003 | 07:50 AM
92rsv8's Avatar
Engine: lo3 carbed
Transmission: t 5
well i got the headers on but the passenger side last 2 bolts are veryslow going they still have about 1/4 and inch or less to go but it is freezing here.. it wouldn't hurt for me to start the car up would it to let it get a little warn in order to tighten them down better?
Old Feb 11, 2003 | 09:21 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
That would be fine, as long as you don't mind going through all this again to replace the exhaust gasket you're about to burn/blow out.
Old Feb 13, 2003 | 08:55 PM
VampireHunterC's Avatar
When I put mine in, as far as the bolts in the rear were concerned, I used the smallest wrench that I had (that would fit the bolt, of course!) and it took a little while due to the cramped space back there. With the engine in the car, there is not much else you can do.
Old Feb 13, 2003 | 09:18 PM
RICHRAD's Avatar
McMinnville...Huh? .. ..Do you know Yogi?
Old Feb 13, 2003 | 09:30 PM
yanfoo's Avatar
Car: Malibu 80, T/A 87, S-15 87
Engine: 267 Bu, 305 T/A, 350 S-15
Transmission: Auto Bu, 5spd T/A, Auto S-15
bolt not going in
92rsv8, yeah i know how it fell like, i have a 88 caprice at work that i'm trying to get the passenger side off. it have AC
anyway i stipped 1 bolt, got 3 off, 1 left to go.
Get a Tap and use it in the hole you have trouble, this will clean, and *fix* the problem, i dont know but maybe you could also try some lube on the bolt (not sure if it a good idea, maybe the lube will "Cook" with the heat and be a pain to remove, or maybe not)
I'll put header on the T/A this summer YAAAYY!!
Good Luck
Old Feb 13, 2003 | 09:51 PM
llvll4l2c91350's Avatar
I would recommend using some penetrating oil on the threads of the bolts before screwing them in. All the bolts on my car went in hard but the oil helped. Also the last bolt on the passenger side didn't go all the way in when it finally got tight. Had to put a washer from one of the exhaust manifold bolts on there.
Old Feb 14, 2003 | 05:39 AM
92rsv8's Avatar
Engine: lo3 carbed
Transmission: t 5
i may have to do the same to the last one on the pside ...but unfortuanitly i can't crank my car now... i must have knocked a wire loose somewhere???... my car won't crank at all no fuel pump hum or anything... i had to push the starter wires over a bit to get them out of the way anybody got a pic of the starter and solinoid? maybe i knocked a wire off??
Old Feb 15, 2003 | 07:04 AM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
I used a 3/8 tap, squirted some wd-40 in all the holes, and chased all of them out. It was amasing the crap that i cleaned out.
Old Feb 15, 2003 | 11:42 AM
I don't know. My wife and I just moved back here last month. We previosly lived here from 1995-1998, so I am not sure.
Old Feb 15, 2003 | 08:39 PM
RICHRAD's Avatar
Noticed that you were from there.. I used to make deliveries (Mr. Tuxedo)to Yogi' men's store on the strip. I think it was called the Country Squire or something similar.
Wesly_66
Aug 26, 2015 09:55 PM
djmarch
Aug 19, 2015 12:07 PM
formula_novice
Aug 18, 2015 08:48 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
drathaar907
Aug 6, 2015 04:20 PM
