Muffler install: bolt on instead of welding
Old Oct 1, 2008 | 05:24 AM
BigBiscuit's Avatar
Car: 86 Iroc-Z28
I need a new muffler, I can't afford to pay a shop to weld it in, and I can't weld. What if I bolted it in with adapters and clamps? Is this a big mistake? will i have serious leaks in a short period of time? is there a heat resistant adhesive I could use with my adapters and clamps to better seal the connections?
I'm planning to get a low end Dynomax (super turbo, i think). Dynomax makes a model I can bolt in. Wanted to know from you guys if welding is really the best option for long term durability, etc.
thanks.
Old Oct 1, 2008 | 09:43 AM
irocz28boy's Avatar
Car: 2000 Z28
Axle/Gears: 10 bolt 4.10s
Re: Muffler install: bolt on instead of welding
Clamping it is perfectly fine.
Old Oct 1, 2008 | 05:40 PM
92RS702's Avatar
Car: 92RS
Engine: 305= boat anchor
Axle/Gears: 4th gen 3.23
Old Oct 1, 2008 | 05:52 PM
nope's Avatar
places like advance and autozone sell this red exhaust fix tape or something idk what it's called, but it's cheap and it's supposed to melt on and seal exhaust leaks, so maybe you could try it. i've never used it myself but i've alwais wondered if it worked or not
Old Oct 2, 2008 | 12:53 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
My whole exhaust was clamped, and it was fine. I then did full exhaust, and used band clamps. No problems and sealed great.
Old Oct 2, 2008 | 07:42 PM
Fords88Bird's Avatar
Car: '88 Firebird Z20
Engine: 305 TBI w/TBI mods
Axle/Gears: Stock
. I've got the Flowmaster 3" system with clamps and a stainless bandclamp to the cat and no leaks. Band clamps are a good idea and give a wide clamping surface. Later.
Old Oct 5, 2008 | 11:14 AM
Jollyrojer's Avatar
Car: 89 formula firebird
Engine: 305 tbi
Transmission: blown 700r4
Axle/Gears: 3.43
4 sure. exhaust on my sonoma is clamped.
Old Oct 7, 2008 | 09:10 PM
Axle/Gears: Stock
Here's part of mine. Later.
Attached Thumbnails Muffler install: bolt on instead of welding-dsc02543.jpg
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
MintWS6FORMULA
Oct 19, 2015 08:53 PM
Dialed_In
Aug 20, 2015 01:45 PM
