Longtube header question
Old Nov 25, 2008 | 03:27 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I'm considering going to longtubes and wanted to know if anyone offers a transmission crossmember for automatics similar to the Skulte T56 piece that permits the exhaust to route close to the trans and maintain ground clearance. Or is this going to be something I'll have to fabricate myself?
Old Nov 25, 2008 | 04:30 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Longtube header question
You haven't got enough room around the pan of an automatic for that kind of routing.
Old Nov 30, 2008 | 01:43 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
Gonna have to fabricate it yourself man.......
Do it right the first time as well, you'll be much happier with the results.
These pics are mine.... and although it works I'm not completely happy with it.
The Y-pipe is squeezed everywhere which sucks and it hangs too low for my liking.... you can see where it scrapes I believe.
Other Pics can be found on one of my other threads..... https://www.thirdgen.org/forums/tran...tallation.html
Old Nov 30, 2008 | 01:49 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
and this is what I would call a good installation with some Fab work....
The Transmission crossmember is cut and welded for clearance and strength. The exhaust pipe (looks Stainless) is mandrel bent and welded correctly and kept high enough out of the way.....
Now this is a nice job!!!!!!
I saved it to my hard-drive to keep as a reference.
Old Nov 30, 2008 | 01:51 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
This is the Cross-member
beautiful work!!!!!
I wish I could take credit for it but I can't.........
Old Nov 30, 2008 | 01:54 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Here's the last one.......
Thanks to whoever posted these pics the first time!!!!! Info like this is spectacular and a picture is worth a thousand words.
Old Nov 30, 2008 | 03:10 PM
Mongoose's Avatar
Car: 90 Formula
Good info but it looks like I'd have to swap to a stick to be able to route the exhaust like I'd planned and keep ground clearance. Oh well, something else for my to do list.
Old Dec 2, 2008 | 11:08 AM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Yea, with an auto, no matter what you do with the crossmember, there is not enough room to sneak it by the trans on the passenger side inside the subframe rails.
Old Dec 2, 2008 | 12:28 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Actually I'm somewhat doing that. I manufactured a new crossmember and will relocate it to the back about 4 inches. This will allow room for an exhaust pipe to run on the passenger side of the transmission.
I have also incorporated a drive shaft loop and moved the torque arm off the transmission to the new crossmember. One could leave the torque arm on the transmission and this would provide more room for an exhaust pipe on the drivers side. I would have to rework mine a little to do that.
Here are some WORK IN PROGRESS pictures. There are gussets to be installed for further strengthening. But this gives you the general idea.
Attached Thumbnails Longtube header question-transmission-cross-member-one   Longtube header question-transmission-cross-member-one   Longtube header question-transmission-cross-member-one
Old Dec 2, 2008 | 12:35 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Nice .......... great Idea!!!!
Old Dec 2, 2008 | 01:00 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
that looks awesome, and the welds are great! but i'd be afraid that the aluminum would crack under stress...super stiff stuff, but doesn't like to flex when it needs to.
Old Dec 2, 2008 | 01:16 PM
Car: 1989 GTA
Engine: 369 TPI
"afraid that the aluminum would crack under stress...super stiff stuff, but doesn't like to flex when it needs to."
Maybe so. We will find out.
Old Dec 5, 2008 | 11:53 AM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
I fabbed up a new transmission cross member with double humps. I run 3.5 inch oval exhaust straight to the rear axel with no bends. There is a thread in the exhaust section some where.
Old Dec 5, 2008 | 07:48 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Do you have any pics???? Or do we have to search the exhaust section????
Old Dec 7, 2008 | 12:34 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
subscribe
Old Dec 7, 2008 | 08:56 AM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
link is in here
https://www.thirdgen.org/forums/orga...bout-your.html
1984HO
Mar 19, 2021 11:59 AM
hayesaw0210
Aug 23, 2015 11:15 PM
tricky1
Aug 23, 2015 01:17 PM
Dialed_In
Aug 20, 2015 01:45 PM
redmaroz
Aug 16, 2015 11:40 PM
