Ebay longtubes
Car: 92 L98 Z28 Heritage Hard Top
Engine: L98 350 w/ HSR,24lbs inj,AFPR
Transmission: TCI Super Street Fighter W/3300 sta
Axle/Gears: 3.73 Detriot NoSpin,LPW cover
Re: Ebay longtubes
Re: Ebay longtubes
Yes, they said they havent had any reports of issues and wanted a pic. I sent them the attached pic of the #8 cyl exhaust port today. All the bolts are in the header flange except the 2 for the #8 Cyl. The outer hole is shown in the pic. You can see the misalignment and to the right of the hole can just see the exhaust port.
Mine look just like this
Car: 1991 firebird formula convertible
Engine: 377 Small block
Transmission: 700R4 Done up
Re: Ebay longtubes
so does anybody know if RPD dropped this header from their lists? I cant seem to find them anymore, if that is the case anybody have a new link on where they can be bought from?
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
Re: Ebay longtubes
Ill be curious to see if they fixed the flange issue with the next batch. Maybe its a good thing I ran out of funny money doing the manual conversion first
. Too bad I won't be able to drive it when im done without headers or exhaust
Car: 92 RS
Engine: 383 FIRST TPI OBDII DBW
Axle/Gears: 3.73 POSI DISK
Re: Ebay longtubes
Well I'm glad they did run out , I got the real stainless works headers and the craftsmanship is worth the 1200 bucks! I did not have one problem with them . But if they do fix the problem I would not mine a pair for the next car.
Re: Ebay longtubes
Mine should be done by Sunday, if the weather holds out
Re: Ebay longtubes
They're no longer listed on ebay?
Re: Ebay longtubes
What a P.I.T.A, ok all done just got to get converters in some how?!?!? So to install these headers you are going to have to remove the starter, steering shaft, oil pressure sending unit (if you have an oil cooler from the factory) notch about 1/2" of the drivers side lower control arm mount. I reused the factory large starter, it's tight, I have a small starter from a 4.3L I will use if this one gets heat soaked, 6 of the 8 spark plugs are very easy to get to 5&6 are a pain, I have a 5/8 box wrench that's for servicing 6.5L deisel fuel injectors that works perfect, car must be at least 3 feet off the ground or on a lift, lift would be best. It took me for ever because my wife was pregnant and we where getting the baby room ready, now that the kid is hear she has loosened the chain and let's me off the porch, albeit not for very long, I am done, just need to figure a muffler and tail pipe set up.
Re: Ebay longtubes
that y merge is horrible
Re: Ebay longtubes
Now my damn car will not start, I have 2 sensors to replace and I hope it will run, or it's getting a PCM for Less LS COMPUTER conversion
Re: Ebay longtubes
Took distributor out and it was a solid rust ball, MSD distributor is on it way
Re: Ebay longtubes
Hope this works, I just want to hear the long tubes sing
Re: Ebay longtubes
Car is running and the long tubes sound amazing
Re: Ebay longtubes
Re: Ebay longtubes
Yea I trashed the Y-pipe and added some cats and will be using a Flowmaster Y
Car: 1989 iroc camaro
Engine: 5.7
Transmission: the auto 700r4
Re: Ebay longtubes
does anyone know the link for the ebay long tubes anymore?
this is all i could find...
was wondering if theyd fit
http://cgi.ebay.com/ebaymotors/CHEVY...item4aae7262a0
Re: Ebay longtubes
No they will not fit
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Re: Ebay longtubes
I emailed OBX but haven't got a response in over a week. Does anybody know where to find these?
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
Re: Ebay longtubes
Are these the same headers:
http://cgi.ebay.com/ebaymotors/CHEVR...#ht_5316wt_948
$135 for stainless steel, $35 shipping.
The Ebay store is called ProAutoPartsCorp.
My car is RHD, and the RHD header seems to angles back and I hope will slear the steering.
Car: 86 Z28
Engine: Built 312
Re: Ebay longtubes
Here's the ones this thread is about:
http://www.amazon.com/OBX-82-92-Cama.../dp/B0053HCFDA
Re: Ebay longtubes
Transmission: T700
Re: Ebay longtubes
Thanks for the tip. Yes they do look like a better option.
I notice they are Procomp P/N pc5011 headers. I've heard that Procomp is a cheap copy of big brands made in China and these headers seem a lot like Hooker headers. The Procomp cost $150 and the Hooker $400.
Does anyone know if the Procomp headers are any good?
Engine: LB9, LB9
Re: Ebay longtubes
1982-1992 CAMARO FIREBIRD HEADER
* G-Body with SBC Engine
These long tube headers are a great replacement over the restrictive factory headers.
Car: 86 Z28
Engine: Built 312
Re: Ebay longtubes
IIRC, you can even use 4th Gen LT1 shorty's.
Re: Ebay longtubes
Those shorties lok like they will fit, they prolly mixed up G and F.
The only prob is the crappy collector design. If I were to buy them (probably will for my 88 camaro), I'd cut off the stepped down part and use a conical shaped reducer to get for a better flowing design. That big neck down in the collector is no good IMO. Weld on some V band flanges and hey would be a nice set of headers. Sure can't beat the price.
Engine: LB9, LB9
Re: Ebay longtubes
I emailed OBX as they aren't even listed on their site anymore...
Skylar,
We are out of stock for 45 days.
Thanks!
Peter
-----Original Message-----
Sent: Sunday, October 09, 2011 7:57 PM
To: info@obxracingsports.com
Subject: Headers
A friend of mine recently got a set of long tube headers and y-pipe for his
82-92 Camaro. I was going to get the same thing but noticed they are not
listed on your site anymore. Is it because of the fitment issues? If so, are
there plans to remedy the issue and rerelease them?
-Skyler
Thanks!
Peter
Subject: Headers
-Skyler
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Ebay longtubes
Sounds like every other header install to me. Long tubes are huge, they're a pain in the ***. The only long tubes I know of to go in truly painlessly are those LS1 swap long tubes.
Read through this for a laugh:
https://www.thirdgen.org/forums/exha...oker-long.html
Car: 1988 TransAm
Engine: sbc 9:8:1 cr 40os slugs rhs heads
Transmission: th400 3800stall b&mkit manual vb
Axle/Gears: stock
Re: Ebay longtubes
no no no not realy i installed many long tube headers so you guys are making it hard espically buying cheapo china knock off headers and why you gotta cut the car if they dont fit well because they are made in china they dont know what a f bodie is in china
they just want dollars
so go give china our money while american supplyers get under cut because of guys like you wanting it for a couple bucks cheaper
Car: 1992 Camaro RS
Re: Ebay longtubes
1. Hooker 2210s = Require grinding and a whole lot of finessing to get them in accordingo to the install link
2. Hedman 68460s = Require a small modification to the a-arm perch, dimple in one of the primaries.
3. Ebay LT's = about the same as those
Maybe those stainless works long tubes fit perfectly, I dont know. Im not advocating everyone go out and buy cheap Chinese headers, but I run cheap Hedman LT's and I'm very happy with them.
Car: 89 Firebird Formula
Engine: 3500T
Axle/Gears: 9 bolt/4.11
Re: Ebay longtubes
Long tubes for thirdgens:
It would be handy to know how the eBay headers fit with an aftermarket k-member. For those of us on a budget stainless headers would be nice but stainless works headers are simply too much (at least for me).
Re: Ebay longtubes
so I'm really kicking myself in the **** for not buying these when I had the chance! damn common sense getting in the way (and the usual fear of retaliation from my wife!!!) has anybody heard anything if OBX is going to be offering these again? I've emailed Racing parts direct a few times and have not had a single response from them concerning these.
am I going have to bite the bullet and buy the stainless works ones at almost 1300$ once they are shipped to Canada
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Ebay longtubes
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Ebay longtubes
Some things apparently are lost in translation to China...
-- Joe
Re: Ebay longtubes
Even if they were only 1-5/8 I would have bought them. The 2.5 collector is a non issue, their collectors are junk anyway. I modified a set of china 4th gen longtubes for under an LS swap 82 corvette... smiply cut off the collector before it necks down and weld on a 3" section.
Re: Ebay longtubes
One thing is strange, the pipes are flattened on the sides to give access to the header bolts, that would lead me to believe they are actually larger. Can someone actually measure these???
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Ebay longtubes
-- Joe
Re: Ebay longtubes
I was thinking about these for a mild build I have a set of 2" primary Hedman Hustlers for when I build something better (the funky ones with the 4 in line collector)
Looks like you will have to fork out some serious money for high $$$ headers
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
Re: Ebay longtubes
i run the obx 3" catback all polished stainless with 3.5" tips . it has great sound an fitment was spot on . only thing i had to do was change clamps theres suck . i've got a post about them anb the install an sound clip : https://www.thirdgen.org/forums/exha...t-obx-cat.html
bump
