Ebay longtubes
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Ebay longtubes
I'll probably put a gauge in the collector at one point and see what the backpressure is like under boost.
-- Joe
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Re: Ebay longtubes
Would you be willing to take inside diameter and outside diameter measurements for the primaries? It doesn't make sense that they used to offer these with 1.75" primaries before and have now switched to 1.5". Unless they got caught with false advertising.
Car: '89 IROC-Z
Engine: LSx
Re: Ebay longtubes
If you look at the picture closely those ports dont look very small especially when you look at them in relation to the bolt holes. They also look to be sqaure port. I have 1 3/4 hookers but thats only top to bottom, side to side is less than 1 1/2 and they wont cover my 195's. Last edited by IROCtheThird; Dec 6, 2012 at 10:49 AM.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Ebay longtubes
If you look at the picture closely those ports dont look very small especially when you look at them in relation to the bolt holes. They also look to be sqaure port. I have 1 3/4 hookers but thats only top to bottom, side to side is less than 1 1/2 and they wont cover my 195's.My afr 210s are 1.63 (felpro 1406).
I emailed Jerami for the exhaust side technical drawings (I only have the intake side) but he's out of the office this week. I'm curious about the exact port location in relation to the bolt holes.
-- Joe
Car: '89 IROC-Z
Engine: LSx
Re: Ebay longtubes
I'm confused. The exhaust ports on the 195s are 1.5x1.5 (felpro 1404).
-- Joe
-- Joe
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Ebay longtubes
You really can't weld a little bit to the side of the ports and grind the inside?
These ebay headers are probably 1.5". I don't understand why the guy who bought them can't just measure them for us. These things appear to be like unicorns. Everyone talks about them but I've yet to meet someone that has a set in their hands.
-- Joe
Car: 85 IROC
Engine: 385AFR head, Mini Ram Intake
Transmission: 6 Sp.
Re: Ebay longtubes
The outside of the wholes are 1.75 by 1.75, but you can tell that it has been grinded to make it that way. There no welds on the sides so I might have mine welded some to give some more meat to the side. The measurement on the inside of the tubing is just under that, about 1 11/16
Re: Ebay longtubes
How large are the primary tubes? Not the opening but the tubes themselves., own from the flange?
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Ebay longtubes
Yes, especially next to the bolt hole. A little tig welding will fix that. Makes me think the primaries are a lot larger than 1.5, you would have broken through the wall with that (crappy) porting.
Car: '89 IROC-Z
Engine: LSx
Re: Ebay longtubes
So I messaged one of the sellers of those headers on ebay and asked what size the ports were. What I got for a response was "1.5" O.D. and 1.25" I.D. approximately" Interesting.
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
Re: Ebay longtubes
Yeah, even the best quality header gaskets are going to have sealing issues there. I hope that's not the case for those who have bought them. I would add a little meat on them for peace of mind.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Ebay longtubes
I'd love to see a set with a dial caliper...
-- Joe
Car: 1991 firebird formula convertible
Engine: 377 Small block
Transmission: 700R4 Done up
Re: Ebay longtubes
so does anybody have an actual mesurement of the primaries of these new OBX headers? I really dont want to drop 1200$ on a set of stainless works plus shipping to Canada....... yeah I know they are awesome but I have a hard time explaining that price to myself.
Car: 1983 Camaro
Engine: LS7
Transmission: TH350
Re: Ebay longtubes
Primaries are ~45mm -> 1 3/4 and y-pipe looks better from inside (post #83)
Re: Ebay longtubes
have you installed them yet to see the fit? and could you get a picture of the ypipe to see for ourselves?
Car: 1983 Camaro
Engine: LS7
Transmission: TH350
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
Re: Ebay longtubes
Well I just bought a set.
I will measure the actual interior dimensions like everyone is asking.
I don't doubt I will need to "adjust" these headers a little but even then I have a good inexpensive template to work with.
$425 shipped to my door including SS y pipe....I'm not complaining....yet
Re: Ebay longtubes
Car: 86' IROC
Engine: 388
Car: 1989 Camaro Iroc Z
Axle/Gears: 9 Bolt Borg Warner/ 2.77 gear
Re: Ebay longtubes
How do you get the obx header to fit on the passenger side? I took off the starter and i removed an engine mount bolt. When i lifted the motor, the header gets stuck on the heater core box.
Re: Ebay longtubes
For future reference to those who install these, I was able to get the passenger side header in by slightly hammering in the outmost pipe about 1/8 of an inch in, then I greased up the a-arm mount the header kept on hitting. After that, the header slid right in with a few taps. If anyone would like a picture of the completed installation, reply to this thread.
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
Re: Ebay longtubes
Definitely want to see pics of these installed. Hopefully a ground clearance shot anywhere it's tight and if you could a drivers side collector shot to see if they clear a t56
Car: 85'Iroc
Engine: 383
Re: Ebay longtubes
Could anyone with these installed give a height reference to the oil pan? How far past the bottom of the pan do they hang. Ground clearance is at a premium, and it'd be a help!
Guest
Posts: n/a
Re: Ebay longtubes
What the HELL IS UP WITH THE COMPANIES THAT CARRY OBX HEADERS. Are these companies legitimate? I have email and Faxed OBX racing but get no response. All I want to know is if the headers are in stock so I can order them.
Ridiculous
Ridiculous
Car: 85 IROC
Transmission: 6 Sp.
Re: Ebay longtubes
Have a set I bought last year I will sell. Going turbo. They were never installed if your interested.
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
Re: Ebay longtubes
Ahh fella's any metal, regardless of coating will eventually corrode or rust eventually.
Cheaper materials in certain aspects of that nature is a given, I myself wouldn't ever spend 700+ for a set of headers or exhaust knowing it was just going to rust.
Some people do, I just couldn't see myself doing it though.
Car: 92 RS 25th Anniversary
Engine: 305 TBI -> 305 TPI
Transmission: T5/T56
Axle/Gears: 3.08 - 3.73+ soon
Re: Ebay longtubes
These look like they're 1 3/4 primary, to a 2.5 coll..
I'm going to reread this whole thread, but I plan to buy these for my
305 tpi t56. It is rebuilt with forged internals, ported and polished heads, bigger cam. I plan to upgrade to a 355 eventually. I want to run a true dual exhaust and dump at the rear end. Will this be overkill until i get to the 355? It will be aways down the road.
Thank you for any replies.
http://www.racingpartdepot.com/servl...maro-SB/Detail
edit: These are supposed to be here tomorrow! woooh. I'll check the flanges to see if they have the problems that a few other people's had!
Re: Ebay longtubes
well. I'll take some pictures tomorrow but i'm having a little problem of all the holes lining up. They're off probably less than 1/8. I'll try again tomorrow when I get some bolts that aren't 3-4" long.. Maybe try something with a smaller head too. Otherwise they look pretty good. I need to trim a little ear off the starter but other than that it doesn't touch anywhere!
I should be able to deal with the clearance issues with just a little persuasion and a drill press.
Re: Ebay longtubes
I've been trying for 3 weeks to get in touch with Racing Parts Depot and OBX to check stock but no luck. They don't answer the phone, fax or emails.
Car: 85'Iroc
Engine: 383
Re: Ebay longtubes
Considered switching to OBX to clear an afr195 exhaust port, and what appears to be more ground clearance, though I would scrap that 2.5" collector for 3" on hotter setups.
Never did get anyone to post a bottom/header to bottom/pan picture & measurement for reference. If your bored, just sayin...
Re: Ebay longtubes
Still am curious if these have more ground clearance than my hooker super comps, which i've now un-dented and welded skid plates on.
I wont have the engine and trans in the car till saturday. But i could get a picture of the headers/oil pan differencw
Re: Ebay longtubes
Yes I'm going to triple post. deal with it
If anyone has any other questions that I can answer while everything is out of the car let me know.
Pictures 1-3 are of header flange problems/ installation
Pictures 4-5 are t56 clearance
Key:
Yellow circle = Header needs dented more to ease installation, or deal with bolt turning against header and smashing your fingers on said headers.
Red circle = ****'s not even close.
1.25" bolts are to long by approx 1/8 of an inch. So invest in either 1.125" bolts or 1" bolts. I'll be going to ACE, AGAIN to get the correct length.
If anyone has any other questions that I can answer while everything is out of the car let me know.Pictures 1-3 are of header flange problems/ installation
Key:
Car: 85'Iroc
Engine: 383
Re: Ebay longtubes
Thanks for posting those pics. Looks like ground clearance is better than hooker 2210s, but those hole alignment problems are scary! Try anything with a smaller head for additional clearance? I've used allen heads, or arp header bolts with the small head.
That #2 primary not so promising. Maybe cut that pipe side flush to the flange / bring the pipe in and open the hole up / have it re-tigged from the inside?
Re: Ebay longtubes
Re: Ebay longtubes
Forget all this. I'm a idiot. Just remove the AC housing and it will slide right in when you pull the engine up a bit. Literally. They just fall in now.. Now to adjust that #2 primary..
Car: 1987 Camaro IROC Z
Engine: LQ9
Re: Ebay longtubes
I know lots of guys may disagree but I always hack off the flanges on my headers. It helps when aligning the bolt holes since the tubes are free to move as I need them to and it looks cleaner when installed. I've installed four sets like this over the years with no issues. I read about it one time in Car Craft magazine.
Car: 85 Z28
Engine: GMPP 350 HSR
Axle/Gears: 4th gen 3.42 Posi LS1
Re: Ebay longtubes
I just got my set of these and they look fn sweet!!! I will be matching up the flange holes on motor that is not in a car to test fit. Also what flowmaster Y are you guys using? How does it match up? Took some measurements and added pics for those wondering.
Primary
Collector
Y pipe outlet
Primary
Collector
Y pipe outlet
Car: RS Camaro
Engine: 97 L31 350:Eventually a stroker
Transmission: WC T-5
Axle/Gears: Zexel Torsen 3.73s
Re: Ebay longtubes
Bump...
So I read through the whole thread trying to figure out weather or not this is a good deal to buy.
also read through that some minor fabin (sorta) will be needed. And do they work with a t-5? I see people with t-56s so it should work or are the slave cyclinders different enough that it matters? What are some opinions!!!!!
