shorty vs long tubes help
Old Jul 25, 2012 | 01:57 PM
kylet8020's Avatar
Car: 88 iroc
Engine: 305 tpi
Transmission: unknown atm
Axle/Gears: unknown atm
Atm I have a stock 305 I'm looking at putting on a full *bolt on exhaust* I'd like to do most the work myself. If I have to have a shop make a y pipe then fine. Plans are to build up the 305 or go with a 350 build going to be a na motor. Reason for the exhaust upgrade is mine is *SHOT* Ive been. Reading a lot about exhaust systems but there is so much info... And I'm lost. First can I buy headers, y pipe and a cat back exhaust and bolt it all up or is this asking to much if so, if I deside to go with a 350 will I have to change anything or will it bolt back up. 2nd what would you recommend. Also I atm I have a 700r4 tranny that's on its way out, plans are to swap to a t56, so any fitting issues with bolting on a exhaust system now and then swaping to the t56?
Old Jul 25, 2012 | 03:04 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: shorty vs long tubes help
Bolt on exhaust means shortys.
Old Jul 25, 2012 | 05:40 PM
kylet8020's Avatar
Car: 88 iroc
Engine: 305 tpi
I can't do long tubes with a catback system having a shop build the y pipe?
Old Jul 25, 2012 | 06:08 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Dyno Dons headers Ypipe will be fine for you.
Do a search for them
Old Jul 25, 2012 | 06:17 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
For a mild street car, definitely shorty's. And you can buy them and a y pipe and a cat back that will all bolt on. Long tubes can be a pain. I have them and they are the lowest part of my car. Not a great feeling hearing $600 headers hit the ground.
Old Jul 26, 2012 | 02:52 AM
kylet8020's Avatar
Car: 88 iroc
Engine: 305 tpi
Thanks and thanks I'll be checking out dyno dons headers. But I gotta ask just couse what is the advantage or disadvantage of running shortly or longs other then longs scraping the ground
Old Jul 26, 2012 | 05:45 AM
built91Z28's Avatar
Long tubes can make more power, but you have to have a motor built enough to need them. My car is built for performance first as it is not a daily driver. I'm making somewhere in the 430 to 450 or so hp range so that's why I went with long tubes.
Old Jul 26, 2012 | 10:30 AM
TTOP350's Avatar
I think Dyno dons car makes 400hp and 430tq to the tire with his headers soooo they are good for many cars, prolly 95% of them on here.
Old Jul 26, 2012 | 11:46 AM
kylet8020's Avatar
Car: 88 iroc
Engine: 305 tpi
Well, I did not give as much info on The motor build as I should have I guess wanna build a 383 stroker na motor and after that get a procharger *p600h* think that was the correct part number.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
z 28 jari
Sep 14, 2021 10:03 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
SG91camaro
Sep 5, 2015 10:27 PM
