Side exit
Old Aug 5, 2018 | 12:25 PM
SketchyZed's Avatar
Car: 1991 camaro z28
Engine: 5.7
Side exit
Would it be possibly to have side exit exhaust like on a 70 superbird/daytona, i drew something the could help explain myself i have hedman longtubes with hedman x-tensions is there a way to go under the frame to do something like this and if its been done can i see some pics please
Old Aug 5, 2018 | 01:01 PM
Buddy's Avatar
Car: '87 FIREGOOSE!!!!
Re: Side exit
Yes it does work, I know some of the cars back in the Players series years ago had side exhaust exits.
Old Aug 5, 2018 | 03:10 PM
SketchyZed's Avatar
Engine: 5.7
Re: Side exit
oh okay just wondering
Old Aug 5, 2018 | 04:09 PM
Ct1987's Avatar
Re: Side exit
Sketchy, nonchalantly shows the car on its side on a mattress. Inquiring minds want to know. How did they do that?
Louis
Old Aug 7, 2018 | 05:58 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Side exit
If the car is not a 4x4, routing in that fashion will provide horrible ground clearance. The players cars routed the pipes directly to the sides around the firewall area then down the pinch rail, where sfc's are usually installed to save ground clearance.
Old Aug 7, 2018 | 06:03 PM
Drew's Avatar
Re: Side exit
Louis
It's an 89 TTA. They did it carefully.... with a mattress. Top. Men.
Old Aug 8, 2018 | 01:31 PM
GTA1990's Avatar
Car: 1991 Trans Am
Engine: L31, LT4 hot cam
Axle/Gears: 3:42 LSD
Re: Side exit
memory foam? anyone know the spec of the mattress?
Old Aug 9, 2018 | 05:59 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: Side exit
Its not worth it, I did this on my car and used moroso spiral mufflers. The exhaust hit everything, finally got sick of it and switched to a big single
Old Aug 9, 2018 | 06:08 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Re: Side exit
Just so you get an idea
Old Aug 9, 2018 | 07:09 AM
SketchyZed's Avatar
Engine: 5.7
Re: Side exit
Im dropping down to a 2.5 inch pipe instead of 3in im gonna try and get it *** close to the frame/body as possible and dump it out right infront of the rear wheels like on the old daytonas and superbirds
Old Aug 9, 2018 | 11:11 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: Side exit
I run dual 2.5" pipes out of hedman longtubes. Mine dump right before the rear axle though, not the side. I have enough ground clearance issues with just that, I can't imagine trying to route side exits.
Old Aug 9, 2018 | 04:26 PM
SUPER CHEVY66's Avatar
Car: 92 camaro, 06 trailblazer ss
Engine: 5.0 tbi, 6.0 ls2
Re: Side exit
i plan to try something similar but with oval tubing and i might end up modifying the floor pan and pinch weld area to give me more clearance.
Old Aug 9, 2018 | 09:42 PM
SketchyZed's Avatar
Engine: 5.7
Re: Side exit
I was just gonna go with some tube like muffler and run it right where the cats went them hook up pipe towards the front of the rear tires
Old Aug 10, 2018 | 08:17 AM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: Side exit
Hopefully it won't look like this.
https://www.thirdgen.org/forums/body...ml#post6243164
Old Aug 10, 2018 | 08:39 AM
SketchyZed's Avatar
Engine: 5.7
Re: Side exit
Oh god no, this is what im aiming for
Old Aug 10, 2018 | 08:57 AM
DynoDave43's Avatar
Re: Side exit
I know. Was just kidding.
I like these. I have them bookmarked for possible use on may van, to get under the upfitter's fiberglass running boards. The boards are too low to the ground to allow for sidepipes (which would be Plan A), so this gives my just a touch of that look, without loosing a meaningful amount of ground clearance.
https://www.ebay.com/itm/Thunder-Exh...s/261141590410
Old Aug 10, 2018 | 09:05 AM
Drew's Avatar
Re: Side exit
Looks like someone was lazy. Like they walked into Checker Auto and asked about an exhaust pipe, muffler and tips, had to debate a moment or two about a few cases of Natty Ice or a decent exhaust, then saw the "Cherry Bomb" display for $7.99.
"One of these, and a $4.99 exhaust elbow, my good man!"
If y'all are really good, I'll tell you the one about the guy <slurred speech>"I'ma building a true dual exhaust for mah El Camino!"</slurred speech> that bought 20 foot of flexible exhaust pipe at $4 bucks a foot.
Old Aug 10, 2018 | 09:51 AM
DynoDave43's Avatar
Re: Side exit
The flex pipe seems to bring out a lot of bad ideas in people.
Old Aug 10, 2018 | 06:07 PM
SketchyZed's Avatar
Engine: 5.7
Re: Side exit
Not exactly like that i just mean the tip poking out
TransAm4u2race
Sep 1, 2001 03:06 AM
Chris 611
Mar 27, 2001 07:47 PM
tzweelz
Oct 6, 2000 10:54 PM
