Header selection
Old Jan 26, 2025 | 08:36 AM
RJ 1's Avatar
Car: 86 Iroc
Engine: 421
Transmission: th400
Axle/Gears: 3:73
Header selection
Hey all,
I'm getting ready to install a 421 in my Iroc and am looking for headers. I'm looking at the ARH short tubes and Doug's long tubes. I really like the thoughts of the short tubes because of clearance and not having to change out my umi th400 crossmember. This engine will not be operating above 6500 rpm. what are your thoughts? I've read about some fitment issues with the Doug's and the lower control arm mount. Does anyone have firsthand experience with either of these choices? Thanks
Old Jan 26, 2025 | 11:38 AM
Buddy's Avatar
Car: '87 FIREGOOSE!!!!
Re: Header selection
ARH is great stuff, high end of the chain.
Old Jan 31, 2025 | 08:51 PM
RJ 1's Avatar
Car: 86 Iroc
Engine: 421
Transmission: th400
Axle/Gears: 3:73
I did a thing 😜
I did a thing 😜
Old Jan 31, 2025 | 10:05 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
What are those? Size/brand I mean...
Old Jan 31, 2025 | 10:16 PM
RJ 1's Avatar
Car: 86 Iroc
Engine: 421
Transmission: th400
Axle/Gears: 3:73
American Racing Headers 1 3/4”
Old Jan 31, 2025 | 11:14 PM
WildCard600's Avatar
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
Keep us updated.
I'm tempted and would like a good firsthand account.
Old Feb 1, 2025 | 12:42 AM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
Did you just get the headers or did you get any other exhaust pipes too?
Old Feb 1, 2025 | 08:48 AM
RJ 1's Avatar
Car: 86 Iroc
Engine: 421
Transmission: th400
Axle/Gears: 3:73
They came with the pipes back to where the cross over is in the picture. I will install a cross over when I get them installed.
Old Feb 1, 2025 | 08:50 AM
RJ 1's Avatar
Car: 86 Iroc
Engine: 421
Transmission: th400
Axle/Gears: 3:73
Originally Posted by WildCard600
Keep us updated.
Will do. I should have them installed by the end of February. I started to order the 1 7/8” but was afraid it would be really hard on plug wires.
Old Feb 15, 2025 | 03:19 PM
RJ 1's Avatar
Car: 86 Iroc
Engine: 421
Transmission: th400
Axle/Gears: 3:73
Here are some pictures of the headers test fit on the engine
Old Mar 19, 2025 | 12:25 PM
RonnieTPI's Avatar
Car: 1991 Camaro Z28 5.0
Transmission: 700 R4
Axle/Gears: Garbage
Hey all,
I see where the ARH sytem includes the pipes that merge into the collector. Is that where I would run a 3" high flo cat and the rest of my exhaust system?
Old Mar 19, 2025 | 01:54 PM
Airwolfe's Avatar
​​​​​​​This is massive overkill for your 1991 LB9 5.0L TPI/700R4 automatic Z28.
Old Mar 19, 2025 | 04:37 PM
Airwolfe's Avatar
Did @RonnieTPI just disappear? It's like him and all his threads and posts just disappeared? I didn't just imagine it all did I? Maybe I'm going crazy.
Old Mar 19, 2025 | 04:43 PM
RonnieTPI's Avatar
Axle/Gears: Garbage
yes all of my stuff dissappear. What happened
Old Mar 19, 2025 | 04:44 PM
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
You're not crazy.
Old Mar 19, 2025 | 04:59 PM
Airwolfe's Avatar
Maybe just a technical glitch or something.
Old Mar 20, 2025 | 09:38 AM
RonnieTPI's Avatar
Axle/Gears: Garbage
Yes, all my threads disappeared. Moderators' please explain.
Old Mar 20, 2025 | 03:20 PM
Airwolfe's Avatar
It was a site issue with the advanced new spam filter. You got sucked into a blackhole but @JT pulled you and your posts and threads back out.
We was hunting for you yesterday. Glad to have you back again.
Site Issue
Old Mar 21, 2025 | 10:03 AM
If you get up under your car and look, you'll see that where the cat now is, is where the little "X" section in the ARH system goes. I'm having a hard time imagining exactly how, butt with some creativity, it might be possible to put a cat there (or 2 of them) instead of the "X" if that's what you want to do. I don't think there's any possible way to put the cat(s) anywhere else.
I would note also, that the pipes in that system, look like they would substantially complicate subframe connector installation.
Old Mar 27, 2025 | 04:01 PM
'91 Formula's Avatar
Car: 1991 Firebird Formula
Engine: 383 Supercharged and Intercooled
Transmission: 6-Speed
Axle/Gears: Stock 10 bolt 3.42
RJ 1, what heads are you running? Got a part number for the heads?
How is the plug clearance?
Old Mar 28, 2025 | 03:38 AM
RJ 1's Avatar
Car: 86 Iroc
Engine: 421
Transmission: th400
Axle/Gears: 3:73
I’m running the AFR Enforcer 200 straight plug 65cc . The plug clearance is fine. Actually better than the headman headers that I was running.
Old Mar 28, 2025 | 09:17 AM
Great! Thanks!
Keep us posted on the install.
Old Mar 29, 2025 | 04:35 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
They look great, have a set ready to go on as well.
Ethan Lesz
Jan 26, 2024 03:55 PM
SketchyZed
Apr 3, 2017 10:33 AM
chevyrules85
Jan 13, 2008 10:02 AM
Randy82WS7
Feb 27, 2007 12:30 PM
trueburton
Mar 14, 2005 08:26 PM
