[OH] Drivers side door
Want a title? Post!
Car: 1991 Chevrolet Camaro RS
Engine: BBC 396 bored .090 over (414) 450HP
Axle/Gears: F**d 9" 3.5:1
Drivers side door
I need a driver's side door, off a camaro power please, with little to no rust and minors dings/ dents close to OH 44312. Thanks.
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
Re: Drivers side door
I have one in pretty good shape, very minor rust on the backside and probably a few dings (it's been a while since I looked at it). It was power window and maybe power lock too. Asking $80, I'm close to Columbus.
Want a title? Post!
Thanks, but I talked to my painter friend and I decided to just buy an after market one and not mess around with filler and things. Sorry, but thanks!
Engine: that I like
That's fine Now I'm curious though, where can you buy an aftermarket door? I didn't know they were available yet.
Want a title? Post!
http://www.summitracing.com/parts/HR...2/?image=large
Car: 85 Iroc
Engine: 461
Transmission: Turbo 400
As far as I know they do not make an aftermarket steel door. Sherman Auto does however make aftermarket door skins. Just no complete door. Also the fiberglass doors are for an off-road only car. You can not put power windows and everything inside them. The door will not support the weight and stresses. Best bet is just keep searching for a clean door locally. It can be done just takes time.
Want a title? Post!
Ok, thats what I'm thinking. The guy I bought my car, from the looks of it, side swiped someone from the drivers side and the internal door frame is just messed up. Do you know if I need a power door to put power accessories on it? My painter friend said is shouldn't matter, but he also mislead me in the placement of my frame rails so now I'm back- halfing the car! Thanks
Car: 85 Iroc
Engine: 461
No you can swap your power regulator into a non power door. I however would recommend finding a clean power door as swaping everything over is a HUGE pain in the butt.
Engine: that I like
Right, it is much nicer when the door guts are already correct. It can be a challenge to switch everything over, especially if you have never done it before.
Car: 1984 Berlinetta
Engine: 355
Transmission: 350
Axle/Gears: 4.30:1
Did you get a door? I have both in very good shape within 2 hrs of you, plus a lot of other parts.
1992 Trans Am
05-10-2023 07:19 PM
1992 Trans Am
Exterior Parts for Sale
04-04-2016 12:50 PM
